Abnormal power consumtion during deep sleep abaut 20% of all Boards Cubecel HTC AB01
Support doesn’t answer any E-Mail.
Grretungs
E_T
Grretungs
E_T
hi,
could you show more details?
Here ist the Topic with pictures of the problem:
Greeting
E_T
I have the same Problem (8mA). Is there a solution or do I have to buy boards until there is a good one?
hi,
could you try this code?
With this code, the board still consumes about 8mA. See photo please.
BTW: Using a AAA battery pack via JST, the power consume is according spec.
What power supply are you using? 5V power? 3.3V pin Power? You mentioned that there is no problem using battery power. Then there should be no problem with 5V power supply and 3.3V pin header power supply. please refer the picture:
Maybe i missed something.
I’m using a 3.7V Lipo battery (up to 4V) on the VIN pin (AB-01 Pinout Diagram) which allows 5V. I don’t find this in your picture, sorry. Shall I try Vext Pin?
Jakob
Please refer the link:
https://resource.heltec.cn/download/CubeCell/HTCC-AB01
Please make sure Vin>= 4.7V.
I suspect that because your power supply voltage is insufficient, the system does not operate properly and thus does not enter the low power consumption correctly.
Therefore, it is normal for you to use this method to test low power consumption。
I will check this option.
But the Spec says, Lithium powering is possible between 3.3V and 4.2V. Which pins shall I use for this?
Please note that the battery power requirement shown in the table you see refers to: the power requirement at A in the figure below。
And the requirement of Vin pin:
I used the same pins (JST plug) for the lipo (3.7V) as for the battery pack (3.3V) and it worked. The low power consumtion was in the aera of micoAmpere. Thank you!
