As far as the libraries, I also experienced some oddities with the Arduino referencing the local AppData folders - not sure why. Here is what I did:
- Deleted all prior libraries (including HELTEC) that I had tried to use to get the V3 board to function from the Documents/Arduino/Libraries folder.
- Extracted the HELTEC esp32-0.0.7 zip file (Link provided by UniquePete)
- Copied ALL of the HELTEC libraries included in the esp32-0.0.7 framework to the Documents/Arduino/Libraries folder. Libraries may or may not be necessary depending on the program. I chose to copy all HELTEC libraries initially just to ensure that any needed dependencies were in place within the Arduini IDE.
- I tested these two example programs: WiFi_LoRa_32_V3_FactoryTest (Lora Receiver) - make sure you set the frequency for your region -&- LoRaSender; again set the frequency.
I am in North America, so I used 915 mHz
/********************************* lora *********************************************/
