I am using HTCC-ABO2A and HTCC-ABO2, but am unable to join console.helium.
I am running Platform.IO
I have a running RAK hotspot in my house.
Thank you for any help you can give me.
joining...TX on freq 903500000 Hz at DR 3 power 20 dBm
Event : Tx Done
RX on freq 926900000 Hz at DR 13
Event : Rx Timeout
RX on freq 923300000 Hz at DR 8
Event : Rx Timeout
TX on freq 902500000 Hz at DR 0 power 20 dBm
Event : Tx Done
RX on freq 923900000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
TX on freq 903300000 Hz at DR 3 power 20 dBm
Event : Tx Done
RX on freq 926300000 Hz at DR 13
Event : Rx Timeout
Event : Rx Timeout
TX on freq 902300000 Hz at DR 0 power 20 dBm
Event : Tx Done
RX on freq 923300000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
TX on freq 903700000 Hz at DR 3 power 20 dBm
Event : Tx Done
RX on freq 927500000 Hz at DR 13
Event : Rx Timeout
Event : Rx Timeout
//C:\Users\terre.platformio\packages\framework-arduinocubecell\libraries\LoRa\src\LoRaWan_APP.h
#include “LoRaWan_APP.h”
#include “Arduino.h”
 * RGB red means sending;
 * RGB blue means RxWindow1;
 * RGB yellow means RxWindow2;
/* OTAA para*/
 uint8_t devEui[] = { 0x49, 0x0A, 0x66, 0xF7, 0x71, 0xF9, 0x81, 0x60 };
 uint8_t appEui[] = { 0xA7, 0x30, 0xB0, 0x82, 0xF6, 0xF9, 0x81, 0x60 };
 uint8_t appKey[] = { 0xAC, 0x51, 0xEF, 0x18, 0xCA, 0x2D, 0x19, 0x00, 0xA7, 0x14, 0x16, 0x4A, 0xF3, 0xE6, 0xC5, 0x25 };
/* ABP para*/
uint32_t devAddr =  ( uint32_t )0x007e6ae1;
LoRaMacRegion_t loraWanRegion = LORAMAC_REGION_US915;
DeviceClass_t  loraWanClass = CLASS_A;
/*the application data transmission duty cycle.  value in [ms].*/
/*OTAA or ABP*/
/*ADR enable*/
bool loraWanAdr = false;
bool keepNet = false;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first)       | DR
* 2               | DR
* 3               | max(DR-1,0)
* 4               | max(DR-1,0)
* 5               | max(DR-2,0)
* 6               | max(DR-2,0)
* 7               | max(DR-3,0)
* 8               | max(DR-3,0)
    appDataSize = 4;
    appData[0] = 0x00;
    appData[1] = 0x01;
    appData[2] = 0x02;
    appData[3] = 0x03;
#if(AT_SUPPORT)
	enableAt();
	LoRaWAN.ifskipjoin();
	switch( deviceState )
		case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
			getDevParam();
			printDevParam();
		case DEVICE_STATE_JOIN:
			LoRaWAN.join();
		case DEVICE_STATE_SEND:
			prepareTxFrame( appPort );
			LoRaWAN.send();
		case DEVICE_STATE_CYCLE:
		case DEVICE_STATE_SLEEP:
			LoRaWAN.sleep();
