PlatformIO LoraWan project code
The Main.cpp class has my HeltecLora class on it.
It instantiates the class the calls hl.Setup(), and hl.Loop();
You need to create a folder in your libraries folder called HeltecLora and place HeltecLora.h and Heltec.cpp in it.
All of the action takes place in this HeltecLora.cpp method
void HeltecLora::prepareTxFrame( uint8_t port )
Comment out my DHT temp humid code, but you can use the battery code as that came from heltec.
Add your devEui, appEui and appKey down at the bottom of this file.
Let me know if you have any platformio questions. I have finally figured out how to run code from it rather than Arduino. I think it is way better.
platformio.ini
[env:cubecell_AB02_lcd]
platform = heltec-cubecell
board = cubecell_board_plus
framework = arduino
monitor_speed = 115200
board_build.mcu = asr6502
board_build.f_cpu = 48000000L
build_src_filter =
	+<main.cpp>
	;+<bat3.cpp>
	;+<HeltecLora.cpp>
lib_extra_dirs =
	c:\source\PlatformIO\_Tps-Libraries
	c:\source\PlatformIO\_Libraries
build_flags = -Wl,-Map,output.map
board_build.arduino.lorawan.region = US915
board_build.arduino.lorawan.class = CLASS_A
board_build.arduino.lorawan.netmode = OTAA
board_build.arduino.lorawan.uplinkmode = UNCONFIRMED
board_build.arduino.lorawan.rgb = ACTIVE
board_build.arduino.lorawan.debug_level = FREQ_AND_DIO ; debug_level can be NONE, FREQ, FREQ_AND_DIO
board_build.arduino.lorawan.adr = OFF
board_build.arduino.lorawan.at_support = OFF
board_build.arduino.lorawan.net_reserve = OFF
[env:cubecell_AB02A_ant]
board = cubecell_node
framework = arduino
build_src_filter =
	+<main.cpp>
	;+<flowmeter.cpp>
	;+<HeltecLora.cpp>
lib_extra_dirs =
board_build.arduino.lorawan.rgb = DEACTIVE
[env:cubecell_AB01]
framework = arduino
build_src_filter =
	+<main.cpp>
	;+<bat3.cpp>
	;+<HeltecLora.cpp>
lib_extra_dirs =
main.cpp
#include <Arduino.h>
#include "HeltecLora.h"
int minBetweenUpload = 15;
HeltecLora hl(minBetweenUpload);
  hl.setup();
  hl.loop();
HeltecLora.h
#ifndef HeltecLora_h
#define HeltecLora_h
	#include "Arduino.h"
	class HeltecLora {
		public:
			HeltecLora(int);
			void setup();
			void loop();
		private:
			void prepareTxFrame( uint8_t );
HeltecLora.cpp
#include "LoRaWan_APP.h"
#include "TpsConfigDHT.h"
int minutesBetweenUpload ;
extern uint32_t UpLinkCounter;
//-------------->> All other properties are at the bottom of this file.
HeltecLora::HeltecLora(int minBetweenUpload){  //Constructor
	minutesBetweenUpload = minBetweenUpload;
void HeltecLora::setup(){
	dht.begin();
	boardInitMcu();
	LoRaWAN.ifskipjoin();
void HeltecLora::loop(){
	switch( deviceState )
		case DEVICE_STATE_INIT:
			printDevParam();
			// This is a runtime API that is in the Heltec github
			// but has not yet made it to the Arduino install
			// version. (1.0.0) It's here for future reference
			// LoRaWAN.setDataRateForNoADR(DR_3);
		case DEVICE_STATE_JOIN:
			LoRaWAN.join();
		case DEVICE_STATE_SEND:
			// Comment out this warning if you "really" do want
			// to enable ADR
			if (loraWanAdr == true)
				Serial.println(">>>> WARNING: ADR is enabled.\n\tThis may reduce the datarate/Spreading Factor after about 100 uplinks");
			prepareTxFrame( appPort );
			LoRaWAN.send();
			// the following is experimental but does seem to
			// re-initialize the connection correctly. See the note
			// at extern UpLinkCounter above
			if (UpLinkCounter == 65534)
				// force a rejoin
		case DEVICE_STATE_CYCLE:
		case DEVICE_STATE_SLEEP:
			LoRaWAN.sleep();
	float temperature = readDHTTemperature(); //this method prints T to Serial
	float humidity = readDHTHumidity(); //this method prints H to Serial
	delay(100);
	unsigned char *puc;
	puc = (unsigned char *)(&temperature);
	appDataSize = 10;
	appData[0] = puc[0];
	appData[1] = puc[1];
	appData[2] = puc[2];
	appData[3] = puc[3];
	puc = (unsigned char *)(&humidity);
	appData[4] = puc[0];
	appData[5] = puc[1];
	appData[6] = puc[2];
	appData[7] = puc[3];
	appData[8] = (uint8_t)(batteryVoltage>>8);
	appData[9] = (uint8_t)batteryVoltage;
	Serial.print("T=");
	Serial.print(temperature);
	Serial.print("C, RH=");
	Serial.print(humidity);
	Serial.print("%,");
	Serial.print("BatteryVoltage:");
	Serial.println(batteryVoltage);
/*the application data transmission duty cycle.  value in [ms].*/
uint32_t appTxDutyCycle = 1000 * 60 * minutesBetweenUpload;
//uint32_t appTxDutyCycle = 1000 * 10 * minutesBetweenUpload;
//AB02-A ant //
uint8_t devEui[] = { 0x60, 0x81, ...};
//AB02 lcd
//uint8_t devEui[] = { 0x60, 0x81... };
uint8_t appEui[] = { 0x60, 0x81, ...};
uint8_t appKey[] = { 0x92, 0x2E, ...};
/* ABP para*/
uint8_t nwkSKey[] = { 0x15, 0xb1, ...};
uint8_t appSKey[] = { 0xd7, 0x2c, ...};
uint32_t devAddr =  ( uint32_t )0x007e6ae1;
/* NOTE: It is very important that these variables be defined correctly in the Platformio.ini file*/
DeviceClass_t  loraWanClass = LORAWAN_CLASS;
/*OTAA or ABP*/
/*ADR enable*/
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first)       | DR
* 2               | DR
* 3               | max(DR-1,0)
* 4               | max(DR-1,0)
* 5               | max(DR-2,0)
* 6               | max(DR-2,0)
* 7               | max(DR-3,0)
* 8               | max(DR-3,0)
// This variable, defined in the runtime, tracks the number of uplinks sent.
// When this count reaches 65,535 the connection must be re-established.
// If you do not the device will continue to send data to the network but
// it will not make it to the Helium console.
// The value is tested below and a reconnection is forced if the counter
//  equals 65534.
// refer to FCnt on this documentation page:
// https://developer.helium.com/longfi/mac-commands-fopts-adr
