I suspect it may be the gateway as well. What can you tell log file?
Fri Jan 10 07:31:52 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_RESP received - token[166:241]
JSON down: {“txpk”:{“imme”:false,“tmst”:768858532,“freq”:926.900000,“rfch”:0,“powe”:20,“ncrc”:false,“modu”:“LORA”,“codr”:“4/5”,“datr”:“SF10BW500”,“ipol”:true,“size”:17,“data”:“IOl5W6QPqPnih2UCjACaJbw=”}}
Fri Jan 10 07:31:52 2020 user.info lora_pkt_fwd[4491]: INFO: Packet ENQUENUE SUCCESS on sx1301 0
Fri Jan 10 07:31:52 2020 daemon.info gwBridge[4531]: [TxAck] - Protobuf size 32
Fri Jan 10 07:31:55 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:31:56 2020 user.info lora_pkt_fwd[4491]: src/lora_pkt_fwd.c:4077:thread_jit(): lgw_send done: count_us=768858532
Fri Jan 10 07:32:00 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:05 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:11 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:12 2020 user.info lora_pkt_fwd[4491]:
INFO: Disabling GPS mode for concentrator’s counter…
Fri Jan 10 07:32:12 2020 user.info lora_pkt_fwd[4491]: INFO: host/sx1301 time offset=(1578658747s:899661µs) - drift=-523µs
Fri Jan 10 07:32:12 2020 user.info lora_pkt_fwd[4491]: INFO: Enabling GPS mode for concentrator’s counter.
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]:
2020-01-10 12:32:12 UTC
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: ### [UPSTREAM] ###
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets received by concentrator: 1
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets forwarded: 1 (23 bytes)
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # PUSH_DATA datagrams sent: 2 (385 bytes)
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: ### [DOWNSTREAM] ###
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # PULL_RESP(onse) datagrams received: 1 (196 bytes)
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets sent to concentrator: 1 (17 bytes)
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # SX1301 time (PPS): 784595471, offset us 0
Fri Jan 10 07:32:12 2020 user.info lora_pkt_fwd[4491]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: ### [GPS] ###
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # Invalid time reference (age: 1578659532 sec)
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: # no valid GPS coordinates available yet
Fri Jan 10 07:32:12 2020 user.debug lora_pkt_fwd[4491]: ##### END #####
JSON up: {“stat”:{“time”:“2020-01-10 12:32:12 UTC”,“lati”:##.87253,“long”:-##.27245,“alti”:40,“rxnb”:1,“rxok”:1,“rxfw”:1,“ackr”:100.0,“dwnb”:1,“txnb”:1,“cpur”:0.0,“memr”:0.0}}
Fri Jan 10 07:32:12 2020 daemon.info gwBridge[4531]: Stats : Protobuf size 98
Fri Jan 10 07:32:12 2020 user.info lora_pkt_fwd[4491]: INFO: [up] PUSH_ACK received in 0 ms
Fri Jan 10 07:32:16 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:21 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:26 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:31 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:37 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:42 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]:
2020-01-10 12:32:42 UTC
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: ### [UPSTREAM] ###
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # RF packets received by concentrator: 0
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # RF packets forwarded: 0 (0 bytes)
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # PUSH_DATA datagrams sent: 1 (178 bytes)
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: ### [DOWNSTREAM] ###
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # RF packets sent to concentrator: 0 (0 bytes)
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # TX errors: 0
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: [truncated] (req:9, rej:0)
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # BEACON queued: 0
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # BEACON sent so far: 0
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # BEACON rejected: 0
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: ### [JIT] ###
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # SX1301 time (PPS): 784595471, offset us 0
Fri Jan 10 07:32:42 2020 user.info lora_pkt_fwd[4491]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: ### [GPS] ###
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # Invalid time reference (age: 1578659562 sec)
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: # no valid GPS coordinates available yet
Fri Jan 10 07:32:42 2020 user.debug lora_pkt_fwd[4491]: ##### END #####
JSON up: {“stat”:{“time”:“2020-01-10 12:32:42 UTC”,“lati”:##.87253,“long”:-##.27245,“alti”:40,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“cpur”:0.0,“memr”:0.0}}
Fri Jan 10 07:32:42 2020 daemon.info gwBridge[4531]: Stats : Protobuf size 90
Fri Jan 10 07:32:42 2020 user.info lora_pkt_fwd[4491]: INFO: [up] PUSH_ACK received in 6 ms
Fri Jan 10 07:32:47 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:52 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:32:57 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:03 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:08 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:12 2020 user.info lora_pkt_fwd[4491]:
Fri Jan 10 07:33:12 2020 user.info lora_pkt_fwd[4491]: INFO: host/sx1301 time offset=(1578658747s:899172µs) - drift=-489µs
Fri Jan 10 07:33:12 2020 user.info lora_pkt_fwd[4491]: INFO: Enabling GPS mode for concentrator’s counter.
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]:
2020-01-10 12:33:12 UTC
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: ### [UPSTREAM] ###
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets received by concentrator: 0
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets forwarded: 0 (0 bytes)
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # PUSH_DATA datagrams sent: 1 (178 bytes)
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: ### [DOWNSTREAM] ###
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # PULL_DATA sent: 5 (100.00 0x0.0000000000005p-992cknowledged)
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets sent to concentrator: 0 (0 bytes)
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: [truncated] (req:9, rej:0)
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # BEACON queued: 0
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # BEACON sent so far: 0
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # BEACON rejected: 0
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: ### [JIT] ###
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # SX1301 time (PPS): 844598358, offset us 0
Fri Jan 10 07:33:12 2020 user.info lora_pkt_fwd[4491]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: ### [GPS] ###
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # Invalid time reference (age: 1578659592 sec)
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: # no valid GPS coordinates available yet
Fri Jan 10 07:33:12 2020 user.debug lora_pkt_fwd[4491]: ##### END #####
JSON up: {“stat”:{“time”:“2020-01-10 12:33:12 UTC”,“lati”:##.87253,“long”:-##.27245,“alti”:40,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“cpur”:0.0,“memr”:0.0}}
Fri Jan 10 07:33:12 2020 daemon.info gwBridge[4531]: Stats : Protobuf size 90
Fri Jan 10 07:33:12 2020 user.info lora_pkt_fwd[4491]: INFO: [up] PUSH_ACK received in 5 ms
Fri Jan 10 07:33:13 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:18 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:23 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:29 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:34 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:39 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]:
2020-01-10 12:33:42 UTC
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: ### [UPSTREAM] ###
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # RF packets received by concentrator: 0
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # RF packets forwarded: 0 (0 bytes)
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # PUSH_DATA datagrams sent: 1 (178 bytes)
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: ### [DOWNSTREAM] ###
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # RF packets sent to concentrator: 0 (0 bytes)
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # SX1301 time (PPS): 844598358, offset us 0
Fri Jan 10 07:33:42 2020 user.info lora_pkt_fwd[4491]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: ### [GPS] ###
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # Invalid time reference (age: 1578659622 sec)
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: # no valid GPS coordinates available yet
Fri Jan 10 07:33:42 2020 user.debug lora_pkt_fwd[4491]: ##### END #####
JSON up: {“stat”:{“time”:“2020-01-10 12:33:42 UTC”,“lati”:##.87253,“long”:-##.27245,“alti”:40,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“cpur”:0.0,“memr”:0.0}}
Fri Jan 10 07:33:42 2020 daemon.info gwBridge[4531]: Stats : Protobuf size 90
Fri Jan 10 07:33:42 2020 user.info lora_pkt_fwd[4491]: INFO: [up] PUSH_ACK received in 6 ms
Fri Jan 10 07:33:44 2020 user.debug lora_pkt_fwd[4491]: INFO: [filter] white list join filter is not enable
Fri Jan 10 07:33:44 2020 user.debug lora_pkt_fwd[4491]: Uplink Frame :
Fri Jan 10 07:33:44 2020 user.debug lora_pkt_fwd[4491]: 00 00 00 00 00 00 00 00
Fri Jan 10 07:33:44 2020 user.debug lora_pkt_fwd[4491]: 00 FA 85 B1 CB 85 EC 79
Fri Jan 10 07:33:44 2020 user.debug lora_pkt_fwd[4491]: 75 DC 07 E9 DF AE 2B
Fri Jan 10 07:33:44 2020 user.info lora_pkt_fwd[4491]:
JSON up: {“rxpk”:[{“tmst”:876586868,“chan”:5,“rfch”:1,“freq”:903.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:10.3,“rssi”:-42,“size”:23,“data”:“AAAAAAAAAAAA+oWxy4XseXXcB+nfris=”}]}
Fri Jan 10 07:33:44 2020 daemon.info gwBridge[4531]: [Uplink] - Protobuf size 136
Fri Jan 10 07:33:44 2020 user.info lora_pkt_fwd[4491]: INFO: [up] PUSH_ACK received in 4 ms
Fri Jan 10 07:33:44 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:44 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_RESP received - token[112:214]
JSON down: {“txpk”:{“imme”:false,“tmst”:881586868,“freq”:926.300000,“rfch”:0,“powe”:20,“ncrc”:false,“modu”:“LORA”,“codr”:“4/5”,“datr”:“SF10BW500”,“ipol”:true,“size”:17,“data”:“IMceqVFl4F+Fs6Y0y3JRP+4=”}}
Fri Jan 10 07:33:44 2020 user.info lora_pkt_fwd[4491]: INFO: Packet ENQUENUE SUCCESS on sx1301 0
Fri Jan 10 07:33:44 2020 daemon.info gwBridge[4531]: [TxAck] - Protobuf size 32
Fri Jan 10 07:33:49 2020 user.info lora_pkt_fwd[4491]: src/lora_pkt_fwd.c:4077:thread_jit(): lgw_send done: count_us=881586868
Fri Jan 10 07:33:49 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:33:54 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:34:00 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:34:05 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:34:10 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:34:12 2020 user.info lora_pkt_fwd[4491]:
Fri Jan 10 07:34:12 2020 user.info lora_pkt_fwd[4491]: INFO: host/sx1301 time offset=(1578658747s:899039µs) - drift=-133µs
Fri Jan 10 07:34:12 2020 user.info lora_pkt_fwd[4491]: INFO: Enabling GPS mode for concentrator’s counter.
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]:
2020-01-10 12:34:12 UTC
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: ### [UPSTREAM] ###
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets received by concentrator: 1
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: [truncated] , CRC_FAIL: 0.00%, NO_CRC: 0.00%
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets forwarded: 1 (23 bytes)
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # PUSH_DATA datagrams sent: 2 (385 bytes)
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: ### [DOWNSTREAM] ###
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # PULL_DATA sent: 6 (100.00 0x0.0000000000005p-992cknowledged)
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # PULL_RESP(onse) datagrams received: 1 (196 bytes)
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # RF packets sent to concentrator: 1 (17 bytes)
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # TX errors: 0
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: [truncated] (req:10, rej:0)
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # BEACON queued: 0
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # BEACON sent so far: 0
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # BEACON rejected: 0
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: ### [JIT] ###
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # SX1301 time (PPS): 904600830, offset us 0
Fri Jan 10 07:34:12 2020 user.info lora_pkt_fwd[4491]: src/jitqueue.c:452:jit_print_queue(): INFO: [jit] queue is empty
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: ### [GPS] ###
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # Invalid time reference (age: 1578659652 sec)
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: # no valid GPS coordinates available yet
Fri Jan 10 07:34:12 2020 user.debug lora_pkt_fwd[4491]: ##### END #####
JSON up: {“stat”:{“time”:“2020-01-10 12:34:12 UTC”,“lati”:##.87253,“long”:-##.27245,“alti”:40,“rxnb”:1,“rxok”:1,“rxfw”:1,“ackr”:100.0,“dwnb”:1,“txnb”:1,“cpur”:0.0,“memr”:0.0}}
Fri Jan 10 07:34:12 2020 daemon.info gwBridge[4531]: Stats : Protobuf size 98
Fri Jan 10 07:34:12 2020 user.info lora_pkt_fwd[4491]: INFO: [up] PUSH_ACK received in 5 ms
Fri Jan 10 07:34:15 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:34:20 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
Fri Jan 10 07:34:26 2020 user.info lora_pkt_fwd[4491]: INFO: [down] PULL_ACK received in 0 ms
