Is there a way to get the Roll Pitch and Yaw output of the Cubecell with the Gyro? Evertime I think I have it figured out, I get nothing.
[SOLVED]Cubecell 9250 Row, Pitch, Yaw
Is MPU9250 can fit your need?
I am using the mpu9250. I just need it to show orientation or yaw pitch and roll. I cannot get the code to display it
perhaps the values magX, magY, magZ fits your needs
I need to track the orientation of an object and set an alert if it travels more than 3 degrees. This is usually done by combining the outputs with formulas from the 9dofs output. But when I add the library for the the math portion I get an error compiling for the cubecell. I am going to try using the BNO055 as it will do the calculations on the board and should output the Yaw pitch and roll orientations to the cubecell .
Do you have already work out the yaw pitch and roll on other platform?
If yes, please provide some more information and let me have a try.
with the last commit to github you can now do this:
mpu9250.computeEulerAngles();
Serial.println("pitch: " + String(mpu9250.pitch()));
Serial.println("roll: " + String(mpu9250.roll()));
Serial.println("yaw: " + String(mpu9250.yaw()));
I will give it try later today and let you know how it works out…Thanks for taking the time to do this.
After a really long day at work, I tried to get one of the examples to run with Roll Pitch and Yaw but was unable to. Can you update one the examples in the librarys or post it here?
I will try to update an example later this day
I see you updated one of the examples. I figured out what I was doing wrong and your example really helped…thanks.
glad you figured it out.
Now to try the interrupt example with the RPY values. Should be fun.
how can i merge the mpu9250 basic with the basic code to connect to TTN through arduino IDE?
have a look at the LoRaWAN MPU9250 example?
If i load just the .ino file i get absurd readings in the configurator but no initialisation to TTN that way. So whats the process here? I got somehow merge the lorawan.ino routine and merge inside the 9250.ino?
Your firmware includes both of these, right?
Heres my code as i merged it, dunno if it right though.
#include "LoRaWan_APP.h"
#include "Arduino.h"
#include <MPU9250.h>
MPU9250 mySensor;
float aX, aY, aZ, aSqrt, gX, gY, gZ, mDirection, mX, mY, mZ;
* RGB red means sending;
* RGB blue means RxWindow1;
* RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t devEui[] = { 0xD0, 0x6D0, 0x44, 0x0B, 0x, 0x92, 0x12, 0xA4 };
uint8_t appEui[] = { 0x, 0x, 0x, 0x7E, 0x, 0x55, 0xF6, 0xE8 };
uint8_t appKey[] = { 0xF*, 0xE, 0xF6, 0x5, 0x8*, 0x**, 0x5, 0xB*, 0x**, 0x4*, 0x7, 0x2, 0xC, 0x2, 0x**, 0x** };
/* ABP para*/
/*OTAA or ABP*/
/*ADR enable*/
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
boardInitMcu();
pinMode(Vext,OUTPUT);
digitalWrite(Vext,LOW);
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
//while(!Serial);
Serial.println("started");
//#ifdef _ESP32_HAL_I2C_H_ // For ESP32
Wire.begin();
mySensor.setWire(&Wire);
//#endif
mySensor.beginAccel();
mySensor.beginGyro();
mySensor.beginMag();
// You can set your own offset for mag values
// mySensor.magXOffset = -50;
// mySensor.magYOffset = -55;
// mySensor.magZOffset = -10;
switch( deviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
uint8_t sensorId;
if (mySensor.readId(&sensorId) == 0) {
Serial.println("sensorId: " + String(sensorId));
} else {
Serial.println("Cannot read sensorId");
if (mySensor.accelUpdate() == 0) {
aX = mySensor.accelX();
aY = mySensor.accelY();
aZ = mySensor.accelZ();
aSqrt = mySensor.accelSqrt();
Serial.println("accelX: " + String(aX));
Serial.println("accelY: " + String(aY));
Serial.println("accelZ: " + String(aZ));
Serial.println("accelSqrt: " + String(aSqrt));
} else {
Serial.println("Cannod read accel values");
if (mySensor.gyroUpdate() == 0) {
gX = mySensor.gyroX();
gY = mySensor.gyroY();
gZ = mySensor.gyroZ();
Serial.println("gyroX: " + String(gX));
Serial.println("gyroY: " + String(gY));
Serial.println("gyroZ: " + String(gZ));
} else {
Serial.println("Cannot read gyro values");
if (mySensor.magUpdate() == 0) {
mX = mySensor.magX();
mY = mySensor.magY();
mZ = mySensor.magZ();
mDirection = mySensor.magHorizDirection();
Serial.println("magX: " + String(mX));
Serial.println("maxY: " + String(mY));
Serial.println("magZ: " + String(mZ));
Serial.println("horizontal direction: " + String(mDirection));
} else {
Serial.println("Cannot read mag values");
Serial.println("at " + String(millis()) + "ms");
Serial.println(""); // Add an empty line
delay(500);
Have you edited something inside this code? Cos i cant tell if you replied
i have not changed the text only the layout for your code to code for easier reading
this is what your code is sending
you need to put all your sensor reading code in the function prepareTxFrame and fill the appData variable with your measured values.
look at an other sensor example for lorawan and use that for a start
