Well my coding skills arent top notch, by the way i used the dedicated code for this device combo under the arduino ide and it seems to work in payload perspective but gives me values of latitude, Longtitude and temperature which is not what MPU9250 gives.
#include “LoRaWan_APP.h”
#include “Arduino.h”
#include <Wire.h>
#include <MPU9250.h>
- set LoraWan_RGB to Active,the RGB active in loraWan
- RGB red means sending;
- RGB purple means joined done;
- RGB blue means RxWindow1;
- RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t appKey[] = { 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x66, 0x01 };
/* ABP para*/
/OTAA or ABP/
/ADR enable/
/* Application port /
uint8_t appPort = 2;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
MPU9250 mySensor;
float aX, aY, aZ, aSqrt, gX, gY, gZ, mDirection, mX, mY, mZ;
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
Wire.begin();
mySensor.setWire(&Wire);
mySensor.beginAccel();
mySensor.beginGyro();
mySensor.beginMag();
// You can set your own offset for mag values
// mySensor.magXOffset = -50;
// mySensor.magYOffset = -55;
// mySensor.magZOffset = -10;
mySensor.accelUpdate();
aX = mySensor.accelX();
aY = mySensor.accelY();
aZ = mySensor.accelZ();
aSqrt = mySensor.accelSqrt();
Serial.print(“aX:”);
Serial.println(aX);
Serial.print(“aY:”);
Serial.println(aY);
Serial.print(“aZ:”);
Serial.println(aZ);
Serial.print(“aSqrt:”);
Serial.println(aSqrt);
mySensor.gyroUpdate();
gX = mySensor.gyroX();
gY = mySensor.gyroY();
gZ = mySensor.gyroZ();
Serial.print(“gX:”);
Serial.println(gX);
Serial.print(“gY:”);
Serial.println(gY);
Serial.print(“gZ:”);
Serial.println(gZ);
mySensor.magUpdate();
mX = mySensor.magX();
mY = mySensor.magY();
mZ = mySensor.magZ();
mDirection = mySensor.magHorizDirection();
Serial.print(“mX:”);
Serial.println(mX);
Serial.print(“mY:”);
Serial.println(mY);
Serial.print(“mZ:”);
Serial.println(mZ);
Serial.print(“mDirection:”);
Serial.println(mDirection);
Wire.end();
digitalWrite(Vext, HIGH);
unsigned char *puc;
puc = (unsigned char *)(&aX);
appDataSize = 46;
appData[0] = puc[0];
appData[1] = puc[1];
appData[2] = puc[2];
appData[3] = puc[3];
puc = (unsigned char *)(&aY);
appData[4] = puc[0];
appData[5] = puc[1];
appData[6] = puc[2];
appData[7] = puc[3];
puc = (unsigned char *)(&aZ);
appData[8] = puc[0];
appData[9] = puc[1];
appData[10] = puc[2];
appData[11] = puc[3];
puc = (unsigned char *)(&gX);
appData[12] = puc[0];
appData[13] = puc[1];
appData[14] = puc[2];
appData[15] = puc[3];
puc = (unsigned char *)(&gY);
appData[16] = puc[0];
appData[17] = puc[1];
appData[18] = puc[2];
appData[19] = puc[3];
puc = (unsigned char *)(&gZ);
appData[20] = puc[0];
appData[21] = puc[1];
appData[22] = puc[2];
appData[23] = puc[3];
puc = (unsigned char *)(&mX);
appData[24] = puc[0];
appData[25] = puc[1];
appData[26] = puc[2];
appData[27] = puc[3];
puc = (unsigned char *)(&mY);
appData[28] = puc[0];
appData[29] = puc[1];
appData[30] = puc[2];
appData[31] = puc[3];
puc = (unsigned char *)(&mZ);
appData[32] = puc[0];
appData[33] = puc[1];
appData[34] = puc[2];
appData[35] = puc[3];
puc = (unsigned char *)(&aSqrt);
appData[36] = puc[0];
appData[37] = puc[1];
appData[38] = puc[2];
appData[39] = puc[3];
puc = (unsigned char *)(&mDirection);
appData[40] = puc[0];
appData[41] = puc[1];
appData[42] = puc[2];
appData[43] = puc[3];
appData[44] = (uint8_t)(batteryVoltage>>8);
appData[45] = (uint8_t)batteryVoltage;
Serial.print(“BatteryVoltage:”);
Serial.println(batteryVoltage);
boardInitMcu();
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
