I have sensor sht30 and it works, sending data to tago.io and i am able to decode value from sensor.
No i would like to add something to my little project and decided to add another sensor BS18B20
Before i will try to start programming ( i am not programmer, but i copy and paste from other project here and use chatGPT hopefully i fogure out something
I would like to ask about two things
if i am using plugable terminal module (below on picture) do i need to add resistor as well ?
Were i should attach red cable VCC from terminal ? Could it be VDD on board ?
Thanks you
