I have a working DS18B20 sensor (works fine on a Wireless Stick). When I try it on the CubeCell capsule it just reports -127. I have it connected to GPIO, Vext, & GND. I’ve tried the onewiresearch sketch and that doesn’t find it either. What am I doing wrong? Thanks. Code is below:
// Include the libraries we need
#include “LoRaWan_APP.h”
#include “Arduino.h”
#include <OneWire.h>
#include <DallasTemperature.h>
#define timetillsleep 1000
#define timetillwakeup 100*60
static TimerEvent_t sleep;
static TimerEvent_t wakeUp;
uint8_t lowpower=1;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
// Data wire is plugged into GPIO1 on the CubeCell
#define ONE_WIRE_BUS 01
#define TEMPERATURE_PRECISION 9
float temp = 0;
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
#define LORA_SPREADING_FACTOR 8 // [SF7…SF12]
#define LORA_CODINGRATE 4 // [1: 4/5,
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000 // was 1000
char txPacket[BUFFER_SIZE];
int16_t rssi,rxSize;
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void setup()
// Vext ON
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
delay(10);
// start serial port
Serial.println(“Dallas Temperature IC Control Library Demo”);
// Start up the library
sensors.begin();
// init LoRa
boardInitMcu( );
temp = 0;
rssi=0;
Radio.Init( &RadioEvents );
Radio.Sleep( );
TimerInit( &sleep, onSleep );
onSleep();
// Vext OFF
digitalWrite(Vext, HIGH);
delay(10);
if(lowpower){
delay(100);
turnOffRGB();
lowPowerHandler();
void onSleep()
Serial.printf(“Going into lowpower mode, %d ms later wake up.\r\n”,timetillwakeup);
lowpower=1;
turnOnRGB(COLOR_JOINED,0);
delay(100);
turnOffRGB();
//timetillwakeup ms later wake up;
TimerSetValue( &wakeUp, timetillwakeup );
TimerStart( &wakeUp );
void onWakeUp()
Serial.printf(“Woke up, %d ms later into lowpower mode.\r\n”,timetillsleep);
lowpower=0;
// Vext ON
// get temp
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print(“Requesting temperatures…”);
sensors.requestTemperatures(); // Send the command to get temperatures
delay(2000);
Serial.println(“DONE”);
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
Serial.print(“Temperature for the device 1 (index 0) is: “);
float temp = (sensors.getTempCByIndex(0));
Serial.println(temp);
// Vext OFF
delay(10);
// TX
sprintf(txPacket,”%s”,“T: “);
sprintf(txPacket+strlen(txPacket),”%d”,temp);
turnOnRGB(COLOR_SEND,0);
delay(100);
turnOffRGB();
Serial.printf("\r\nsending packet “%s” , length %d\r\n",txPacket, strlen(txPacket));
Radio.Send( (uint8_t *)txPacket, strlen(txPacket) );
TimerStart( &sleep );
