HERE IS THE CODE
#include “LoRaWan_APP.h”
#include “Arduino.h”
#include <Wire.h>
#include “HDC1080.h”
/* OTAA para*/
uint8_t devEui[] = XXXXXXXXXXXXXXXXX; //CHANGE
uint8_t appKey[] = XXXXXXXXXXXXXXXXX; //CHANGE
uint8_t appEui[] = XXXXXXXXXXXXXXXXX; //CHANGE
/* ABP para*/
//uint16_t userChannelsMask[6]={ 0x00FF,0x0000,0x0000,0x0000,0x0000,0x0000 };
/LoraWan channelsmask, default channels 0-15 - 64 and 65/
uint16_t userChannelsMask[6]={ 0xFFFF,0x0000,0x0000,0x0000,0x0003,0x0000 };
uint32_t appTxDutyCycle = 20000;
/OTAA or ABP/
/ADR enable/
/* Application port */
uint8_t appPort = 2;
\brief Prepares the payload of the frame
HDC1080 hdc1080;
pinMode(Vext,OUTPUT);
digitalWrite(Vext,LOW);
hdc1080.begin(0x40);
float temperature = (float)(hdc1080.readTemperature());
float humidity = (float)(hdc1080.readHumidity());
hdc1080.end();
digitalWrite(Vext,HIGH);
unsigned char *puc;
puc = (unsigned char *)(&temperature);
appDataSize = 10;
appData[0] = puc[0];
appData[1] = puc[1];
appData[2] = puc[2];
appData[3] = puc[3];
puc = (unsigned char *)(&humidity);
appData[4] = puc[0];
appData[5] = puc[1];
appData[6] = puc[2];
appData[7] = puc[3];
appData[8] = (uint8_t)(batteryVoltage>>8);
appData[9] = (uint8_t)batteryVoltage;
Serial.print(“T=”);
Serial.print(temperature);
Serial.print(“C, RH=”);
Serial.print(humidity);
Serial.print("%,");
Serial.print(“BatteryVoltage:”);
Serial.println(batteryVoltage);
boardInitMcu();
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
