Sorry for the late reply, just back from a long business trip. Do you have any information about the antenna?
Regarding the antenna, can you try the following?
- Choose an intermediate distance, don’t use the furthest distance;
- Test the RSSI value serial times;
- Separately replace the antenna of your gateway and node and write down the RSSI value!
This is in order to verify if the antenna makes witch side better.
