I am working with the example code and have successfully run the code on my CubeCell. The device did join my TTN gateway, and is transmitting data every 15 seconds. However, I am wanting to put this unit into sleep mode and only transmit every 15 minutes. I found more example code, however, when I integrated the two examples, I am not getting any data to the gateway.
#include "LoRaWan_APP.h"
#include "Arduino.h"
#define timetosleep 20000
#define timetowake 20000
static TimerEvent_t sleep;
static TimerEvent_t wakeup;
uint8_t lowpower=1;
* RGB red means sending;
* RGB blue means RxWindow1;
* RGB yellow means RxWindow2;
void OnSleep()
Serial.printf("into lowpower mode, %d ms later wake up.\r\n",timetowake);
lowpower=1;
//timetosleep ms later wake up;
TimerSetValue( &wakeup, timetowake );
TimerStart( &wakeup );
void OnWakeup()
Serial.printf("wake up, %d ms later into lowpower mode.\r\n",timetosleep);
lowpower=0;
//timetosleep ms later into lowpower mode;
TimerSetValue( &sleep, timetosleep );
TimerStart( &sleep );
/*LoraWan Class*/
DeviceClass_t CLASS=LORAWAN_CLASS;
/*OTAA or ABP*/
bool OVER_THE_AIR_ACTIVATION = LORAWAN_NETMODE;
/*ADR enable*/
bool LORAWAN_ADR_ON = LORAWAN_ADR;
bool KeepNet = LORAWAN_Net_Reserve;
/*LoraWan REGION*/
LoRaMacRegion_t REGION = ACTIVE_REGION;
bool IsTxConfirmed = true;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
uint8_t ConfirmedNbTrials = 8;
/* Application port */
uint8_t AppPort = 2;
uint32_t APP_TX_DUTYCYCLE = 15000;
static void PrepareTxFrame( uint8_t port )
AppDataSize = 4;//AppDataSize max value is 64
AppData[0] = 0x00;
AppData[1] = 0x01;
AppData[2] = 0x02;
AppData[3] = 0x03;
BoardInitMcu();
BoardInitMcu();
Radio.Sleep( );
TimerInit( &sleep, OnSleep );
TimerInit( &wakeup, OnWakeup );
OnSleep();
#if(AT_SUPPORT)
Enable_AT();
DeviceState = DEVICE_STATE_INIT;
LoRaWAN.Ifskipjoin();
void loop(){
if(lowpower){
//note that LowPower_Handler() run six times the mcu into lowpower mode;
LowPower_Handler();
switch( DeviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
Serial.printf("LoRaWan Class%X start! \r\n",CLASS+10);
LoRaWAN.Init(CLASS,REGION);
DeviceState = DEVICE_STATE_JOIN;
case DEVICE_STATE_JOIN:
LoRaWAN.Join();
case DEVICE_STATE_SEND:
PrepareTxFrame( AppPort );
LoRaWAN.Send();
DeviceState = DEVICE_STATE_CYCLE;
case DEVICE_STATE_CYCLE:
TxDutyCycleTime = APP_TX_DUTYCYCLE + randr( 0, APP_TX_DUTYCYCLE_RND );
LoRaWAN.Cycle(TxDutyCycleTime);
DeviceState = DEVICE_STATE_SLEEP;
case DEVICE_STATE_SLEEP:
LoRaWAN.Sleep();
