I’ve tried to use the LoRaWAN library that Heltec provides but I had some problems with it.
- First, the guide is not updated. When you install the library, it doesn´t appear the option of choosing the Region in the Arduino tools menu. I think I resolve that changing this line of code:
LoRaMacRegion_t loraWanRegion = LORAMAC_REGION_EU868;
- Second, once that you compile and upload the program, as soon an it tries to do the join, it reboots. I obtain this message:
ESP32 MCU init... ESP32 MCU inited OK! LoRaWAN EU868 Class C start! joining... Guru Meditation Error: Core 1 panic'ed (StoreProhibited). Exception was unhandled. Core 1 register dump: PC : 0x400d46d3 PS : 0x00060330 A0 : 0x800d4466 A1 : 0x3ffb1ef0 A2 : 0x3ffb1f24 A3 : 0x3ffb1f1c A4 : 0x00000031 A5 : 0x00000000 A6 : 0x3ffb8f22 A7 : 0x00000006 A8 : 0x00000000 A9 : 0x00000001 A10 : 0x00000000 A11 : 0x3ffc1d88 A12 : 0x3ffc02fc A13 : 0x00000000 A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x0000001b EXCCAUSE: 0x0000001d EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff Backtrace: 0x400d46d3:0x3ffb1ef0 0x400d4463:0x3ffb1f10 0x400d6dd3:0x3ffb1f50 0x400d11db:0x3ffb1f90 0x400d9b39:0x3ffb1fb0 0x40088f4d:0x3ffb1fd0 Rebooting...
- Third, everytime I compile the program I obtain this message that doesn´t stop the upload of the code, but I think that something is wrong:
Invalid version ‘Internal RTC2.0’ for library in: C:\Users\Dani\Documents\Arduino\libraries\ESP32_LoRaWAN-master
I am trying this with a Heltec WiFi LoRa 32 (V2), a RG1xx Laird Gateway and Chirpstack.
Can anyone help me? Thank you.
