Esp32 V2 rebooting... and Compiling error 2 today: Mcu.h:10: error: unterminated #ifndef
addition:
was thinking to use heltec in commercial project… but this is… :
I tried this: LoRaWAN Library doesn´t work
new pull from Github,
new installation,
first, still does not compile in Arduino IDE, compiles with errors in PIO, but then still getting this (on OS X):
15:01:19.434 -> Rebooting…
15:01:20.098 -> ESP32 MCU init…
15:01:20.098 -> ESP32 MCU inited OK!
15:01:20.767 ->
15:01:20.767 -> DevEui=2085237B759921B3
15:01:20.767 -> LoRaWAN EU868 Class A start!
15:01:20.767 ->
15:01:21.188 -> joining…
15:01:21.188 -> Guru Meditation Error: Core 1 panic’ed (StoreProhibited). Exception was unhandled.
15:01:21.188 -> Core 1 register dump:
15:01:21.188 -> PC : 0x400d469b PS : 0x00060530 A0 : 0x800d442e A1 : 0x3ffb1ef0
15:01:21.221 -> A2 : 0x3ffb1f24 A3 : 0x3ffb1f1c A4 : 0x00000031 A5 : 0x00000008
15:01:21.221 -> A6 : 0x0000005e A7 : 0x00000006 A8 : 0x00000000 A9 : 0x00000001
15:01:21.221 -> A10 : 0x00000000 A11 : 0x3ffc01e8 A12 : 0x3ffc019c A13 : 0x00000000
15:01:21.221 -> A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x0000001b EXCCAUSE: 0x0000001d
15:01:21.255 -> EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
15:01:21.255 ->
15:01:21.255 -> ELF file SHA256: 0000000000000000
15:01:21.255 ->
15:01:21.255 -> Backtrace: 0x400d469b:0x3ffb1ef0 0x400d442b:0x3ffb1f10 0x400d18eb:0x3ffb1f50 0x400d131f:0x3ffb1f90 0x400d9ce5:0x3ffb1fb0 0x40087381:0x3ffb1fd0
15:01:21.255 ->
15:01:21.255 -> Rebooting…
I just want to test the example files actory_Test_Wifi_LoRa32_V2 the next error occurs (my board is registered at Heltec):
In file included from /Users/user2/Documents/Arduino/libraries/ESP32_LoRaWAN-master/src/ESP32_LoRaWAN.h:8,
from /Users/user2/Documents/Arduino/libraries/ESP32_LoRaWAN-master/examples/FactoryTest/Factory_Test_Wifi_LoRa32_V2/Factory_Test_Wifi_LoRa32_V2.ino:1:
/Users/user2/Documents/Arduino/libraries/ESP32_LoRaWAN-master/src/Mcu.h:10: error: unterminated #ifndef
#ifndef McuSet_H\
WIFI_Lorawan example shoes the same error…
regards,
Tobias
