- I have used 868 frequency. I have flashed by going to flash --> Flash Firmware.
This is the full log
28.12.19 23:19:28: +OK
28.12.19 23:19:28: Copyright @ 2019 Heltec Automation.All rights reserved.
28.12.19 23:19:28: Sensor Port Scanning…
28.12.19 23:19:28: No Sensors found
28.12.19 23:19:28:
28.12.19 23:19:28: AT Rev 0.5
28.12.19 23:19:28:
28.12.19 23:19:28: +LORAWAN=1
28.12.19 23:19:28:
28.12.19 23:19:28: +KeepNet=0
28.12.19 23:19:28: +OTAA=1
28.12.19 23:19:28: +Class=A
28.12.19 23:19:28: +ADR=1
28.12.19 23:19:28: +IsTxConfirmed=0
28.12.19 23:19:28: +AppPort=2
28.12.19 23:19:28: +DutyCycle=900000
28.12.19 23:19:28: +ConfirmedNbTrials=8
28.12.19 23:19:28: +DevEui=2232330000888802(For OTAA Mode)
28.12.19 23:19:28: +AppEui=70B3D57ED0027EF2(For OTAA Mode)
28.12.19 23:19:28: +AppKey=87AB76E8E51A7477F75B41E989E2BB1F(For OTAA Mode)
28.12.19 23:19:28: +NwkSKey=D72C78758CDCCABF55EE4A778D16EF67(For ABP Mode)
28.12.19 23:19:29: +AppSKey=15B1D0EFA463DFBE3D11181E1EC7DA85(For ABP Mode)
28.12.19 23:19:29: +DevAddr=007E6AE1(For ABP Mode)
28.12.19 23:19:29:
28.12.19 23:19:29: +LED=1
28.12.19 23:19:29:
28.12.19 23:19:29: LoRaWan Class A start!
28.12.19 23:19:29: joining…
28.12.19 23:19:34: joined
28.12.19 23:19:35: Scan for OneWire Sensors …
28.12.19 23:19:35: No OneWire Sensors found.
28.12.19 23:19:35: BatteryVoltage: 4158
28.12.19 23:19:35: confirmed uplink sending …
28.12.19 23:19:35: unconfirmed uplink sending …
I tried with only HDC1080 SENSOR Below is the log
28.12.19 23:26:36: Downloadind Firmware …
28.12.19 23:26:37: Downloading Firmware done
28.12.19 23:26:37: Flashing Firmware …
28.12.19 23:26:40: Initialising bootloader.
28.12.19 23:26:40: Silicon ID 0x256a11b5, revision 0.
28.12.19 23:26:40: Verifying rows.
28.12.19 23:26:40: Array 0: first row 34, last row 511.
28.12.19 23:26:40: Starting upload.
28.12.19 23:26:40: Uploading ( 10 / 100 )
28.12.19 23:26:42: Uploading ( 20 / 100 )
28.12.19 23:26:44: Uploading ( 30 / 100 )
28.12.19 23:26:46: Uploading ( 40 / 100 )
28.12.19 23:26:48: Uploading ( 50 / 100 )
28.12.19 23:26:51: Uploading ( 60 / 100 )
28.12.19 23:26:53: Uploading ( 70 / 100 )
28.12.19 23:26:55: Uploading ( 80 / 100 )
28.12.19 23:26:57: Uploading ( 90 / 100 )
28.12.19 23:27:00: Uploading ( 100 / 100 )
28.12.19 23:27:00: Checksum verifies OK.
28.12.19 23:27:00: Rebooting.
28.12.19 23:27:00: Total upload time 22.53s
28.12.19 23:27:00: Flashing Firmware done
28.12.19 23:27:00: CleanUp Starting
28.12.19 23:27:00: CleanUp done
28.12.19 23:27:16: Copyright @ 2019 Heltec Automation.All rights reserved.
28.12.19 23:27:16: 28.12.19 23:27:16: +OK
28.12.19 23:27:16: +DutyCycle=0
28.12.19 23:27:16: +IsTxConfirmed=0
28.12.19 23:27:17: Sensor Port Scanning…
28.12.19 23:27:17: Found HDC1080
28.12.19 23:27:17: Found ADS1015
28.12.19 23:27:17: Found VL53L1X
28.12.19 23:27:18: Found CCS811
28.12.19 23:27:18: Found MPU9250
and it get stuck over there…
And thanks from the heart for bringing up this easy to use application.
