Good morning everyone. I am trying to read the data from this flow sensor indicated in the subject, but the interrupts on the board do not work for me. The same code on an arduino uno works without problems. I have tried the example that brings gpiointerrupt but it does not read anything either, only when I remove or put back the cable that comes from the flow sensor to the pin it shows some value, but passing water through it does not show anything at all. I have used these two codes to test:
#include “Arduino.h”
uint32_t cnt = 0;
void cntIncrease()
cnt++;
Serial.println(cnt);
PINMODE_INPUT_PULLDOWN(GPIO3);
attachInterrupt(GPIO3,cntIncrease,RISING);
OTHER CODE TESTED
const int sensorPin = GPIO3;
const int measureInterval = 2500;
volatile int pulseConter;
// YF-S201
const float factorK = 7.5;
// FS300A
//const float factorK = 5.5;
// FS400A
//const float factorK = 3.5;
void ISRCountPulse()
pulseConter++;
float GetFrequency()
pulseConter = 0;
interrupts();
delay(measureInterval);
noInterrupts();
return (float)pulseConter * 1000 / measureInterval;
void setup()
Serial.begin(9600);
attachInterrupt(digitalPinToInterrupt(sensorPin), ISRCountPulse, RISING);
// obtener frecuencia en Hz
float frequency = GetFrequency();
// calcular caudal L/min
float flow_Lmin = frequency / factorK;
Serial.print(“Frecuencia: “);
Serial.print(frequency, 0);
Serial.print(” (Hz)\tCaudal: “);
Serial.print(flow_Lmin, 3);
Serial.println(” (L/min)”);
