Write to UC6580 on Heltec Tracker V1.2?
Has anyone successfully sent commands to the UC6580 chip fitted to the Heltec Tracker V1.2?
I am trying to reduce the number of GNSS messages sent to the ESP32, which involves sending configuration messages to turn off the unwanted messages.
The following code snippet requests product information from the UC6580, but the chip fails to respond. I suspect the message is not reaching the chip.
const char* PRODUCT_INFO = “$PDTINFO\r\n”;
void initialiseGPS() {
Serial1.begin(115200, SERIAL_8N1, 33, 34); // start GPS serial port
// Request Configuration details
Serial.println(“Request GPS Config”);
Serial1.print(PRODUCT_INFO);
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW); // turn on GPS Chip
initialiseGPS();
if (Serial1.available() > 0) {
Serial.write(Serial1.read()); // output raw GNSS strings
delay(10);
More details
The above code snippet shows the UC6580 continuously outputs multiple messages. I only need the RMC message and am trying to turn off unwanted message strings including GGA, GLL, GSA, GSV and VTG.
Solved …
The UC6580 sends location updates when Vext is set to OUTPUT with either LOW or HIGH !!!
However on the V1.2 hardware it must be set HIGH to enable two-way communications.
