Hey,
I managed to compile code for the tracker in Platformio using the board config from your repo, but for some reason I have problems uploading it to the board and get following error:
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s3-devkitc-1.html
PLATFORM: Espressif 32 (5.4.0) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 3.20006.221224 (2.0.6)
- tool-esptoolpy @ 1.40400.0 (4.4.0)
- tool-mkfatfs @ 2.0.1
- tool-mklittlefs @ 1.203.210628 (2.3)
- tool-mkspiffs @ 2.230.0 (2.30)
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch5
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch5
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 43 compatible libraries
Scanning dependencies...
Dependency Graph
|-- RadioLib @ 7.7.1
|-- APRSPacketLib @ 1.0.4
|-- TinyGPSPlusPlus @ 0.0.4
|-- Adafruit ST7735 and ST7789 Library @ 1.11.0
|-- gpx
|-- rapidxml
|-- SD @ 2.0.0
|-- SPI @ 2.0.0
|-- lora_aprs
|-- Adafruit GFX Library @ 1.12.6
Building in release mode
Retrieving maximum program size .pio\build\heltec_wifi_lora_32_V2\firmware.elf
Checking size .pio\build\heltec_wifi_lora_32_V2\firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [=== ] 26.8% (used 87848 bytes from 327680 bytes)
Flash: [= ] 11.4% (used 382345 bytes from 3342336 bytes)
Configuring upload protocol...
AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port...
Auto-detected: COM18
Uploading .pio\build\heltec_wifi_lora_32_V2\firmware.bin
esptool.py v4.4
Serial port COM18
Connecting...
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: (MAC address)
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x0006dfff...
Compressed 14768 bytes to 10149...
Writing at 0x00000000... (100 %)
Wrote 14768 bytes (10149 compressed) at 0x00000000 in 0.2 seconds (effective 618.5 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.0 seconds (effective 616.6 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 870.6 kbit/s)...
Compressed 382736 bytes to 213970...
Writing at 0x00010000... (7 %)
Writing at 0x0001abda... (14 %)
Writing at 0x0002a75e... (21 %)
Writing at 0x0002fb0a... (28 %)
Writing at 0x000353b6... (35 %)
Traceback (most recent call last):
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool.py", line 34, in <module>
esptool._main()
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\__init__.py", line 1026, in _main
main()
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\__init__.py", line 826, in main
operation_func(esp, args)
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\cmds.py", line 556, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\loader.py", line 109, in inner
return func(*args, **kwargs)
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\loader.py", line 991, in flash_defl_block
self.check_command(
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\loader.py", line 407, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\loader.py", line 376, in command
p = self.read()
File "C:\Users\user\.platformio\packages\tool-esptoolpy\esptool\loader.py", line 308, in read
return next(self._slip_reader)
StopIteration
*** [upload] Error 1
Then after few tries it successfully uploads the code to the board, but nothing happens as there should be text on the built-in display, in the serial monitor then there is this message:
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403773a0
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbec
load:0x403cc700,len:0x2920
entry 0x403c98d8
E (153) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
ESP-ROM:esp32s3-20210327
Erasing flash didn’t help, also I wasn’t able to find something helpful online, but on the other hand sometimes I was able to upload code and it ran without problems, so I am confused what is actually the issue here. Source code for this project can be found here. Thanks for the suggestions.
