Wireless Tracker : bits/error_constants.h: No such file or directory
I’m following the guide https://docs.heltec.org/en/node/esp32/esp32_general_docs/quick_start.html and when I try to compile I’ve got the error : bits/error_constants.h: No such file or directory
I have tested with the WiFi LoRa 32(V2) WiFi LoRa 32(V3) and Wireless Tracker board. I also try to erase every thing and start from scratch but still the same problem. Has anyone experienced the same problem ?
Thanks a lot
Christophe
We noticed that this issue occurs when installing the environment through the Arduino library manager.
This is an issue that we are fixing. If convenient, please install our environment using Git.
