My stick is no longer function. A red light flashes briefly when I plug it in and then nothing. I also can reflash via the Meshtastic web flasher. It was working fine before.
I did also notice the 5 pin IC labelled “9A29” VERY hot when I plug in the usb c. I suspect its burnt up. Anyone know what component this is, if it can be replaced and where i could find the part?
