Hello, I am using a Heltec Wireless Stick Lite V3 development board and I want to connect the node to my gateway. First of all, I have already done the corresponding node-to-node tests and it worked. However, when I tried to use the LORAWAN protocol, I was unable to connect it following the steps from the Heltec information platform with the following code:
I am using the following:
1.-Heltec ESP32 Dev-Boards 2.1.1
2.-board Wireless Stick Lite(V3)
3.-https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
- This is the sample code I use for the connection
/* Heltec Automation LoRaWAN communication example
Function:
- Upload node data to the server using the standard LoRaWAN protocol.
Description:
- Communicate using LoRaWAN protocol.
HelTec AutoMation, Chengdu, China
成都惠利特自动化科技有限公司
#include “LoRaWan_APP.h”
/* OTAA para*/
uint8_t devEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x06, 0x53, 0xC8 };
uint8_t appKey[] = { 0x74, 0xD6, 0x6E, 0x63, 0x45, 0x82, 0x48, 0x27, 0xFE, 0xC5, 0xB7, 0x70, 0xBA, 0x2B, 0x50, 0x45 };
/* ABP para*/
/OTAA or ABP/
/ADR enable/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
Number of trials to transmit the frame, if the LoRaMAC layer did not
receive an acknowledgment. The MAC performs a datarate adaptation,
according to the LoRaWAN Specification V1.0.2, chapter 18.4, according
to the following table:
Transmission nb | Data Rate
1 (first) | DR
2 | DR
3 | max(DR-1,0)
4 | max(DR-1,0)
5 | max(DR-2,0)
6 | max(DR-2,0)
7 | max(DR-3,0)
8 | max(DR-3,0)
Note, that if NbTrials is set to 1 or 2, the MAC will not decrease
the datarate, in case the LoRaMAC layer did not receive an acknowledgment
appDataSize = 4; appData[0] = 0x00; appData[1] = 0x01; appData[2] = 0x02; appData[3] = 0x03;}
//if true, next uplink will add MOTE_MAC_DEVICE_TIME_REQ
Mcu.begin(HELTEC_BOARD,SLOW_CLK_TPYE);
switch( deviceState )
case DEVICE_STATE_INIT: {#if(LORAWAN_DEVEUI_AUTO)
LoRaWAN.generateDeveuiByChipID();#endif
LoRaWAN.init(loraWanClass,loraWanRegion); //both set join DR and DR when ADR off LoRaWAN.setDefaultDR(3); break; } case DEVICE_STATE_JOIN: { LoRaWAN.join(); break; } case DEVICE_STATE_SEND: { prepareTxFrame( appPort ); LoRaWAN.send(); deviceState = DEVICE_STATE_CYCLE; break; } case DEVICE_STATE_CYCLE: { // Schedule next packet transmission txDutyCycleTime = appTxDutyCycle + randr( -APP_TX_DUTYCYCLE_RND, APP_TX_DUTYCYCLE_RND ); LoRaWAN.cycle(txDutyCycleTime); deviceState = DEVICE_STATE_SLEEP; break; } case DEVICE_STATE_SLEEP: { LoRaWAN.sleep(loraWanClass); break; } default: { deviceState = DEVICE_STATE_INIT; break; }}
2024-09-10T05:00:00Z
