You guys did some modifications that were great ( changing parameters in .INO much better than change in the .h)
However theses modifications made the 915 MHz stop to work. Can you guys check?
Another thing is, when it goes to sleep with your lib (LoRaWAN) it consumes around 1,8 mA. The problem is in the lib not the hardware. Can you check this too?
