We connect with the Wireless Stick ESP32 to an application via TTN and OTAA. Authentication to the application is successful. If we send data to the application in the second step, the Stick crashes with the errormessage on the serial console (Arduino IDE) “…\libraries\MCCI_LoRaWAN_LMIC_library\src\lmic\radio.c:1065”. Research on google reveals that it may be a hardware problem. The Wireless Stick is new and out of the box. A second Stick shows the same error.
How can I fix the problem?
Wireless Stick ESP32 - LMIC problem
we change to the following configuration:
After this change the stick works for about 50 minutes and then crashes.
Here the LMIC debug information of a normal transmission and at the end in the event of a crash.
22:32:03.732 -> GEIGER: 15 9814 1.528429 0.124473 1 788 597528 1.318767 0.107398
22:32:07.672 -> GEIGER: Sending to TTN …
22:32:07.706 -> 37657825: engineUpdate, opmode=0x908
22:32:07.706 -> 37657924: TXMODE, freq=867100000, len=23, SF=7, BW=125, CR=4/5, IH=0
22:32:12.745 -> 37972289: setupRx1 txrxFlags 0x20 --> 01
22:32:12.745 -> start single rx: now-rxtime: 4
22:32:12.745 -> 37972921: RXMODE_SINGLE, freq=867100000, SF=7, BW=125, CR=4/5, IH=0
22:32:12.779 -> rxtimeout: entry: 37975945 rxtime: 37972914 entry-rxtime: 3031 now-entry: 4 rxtime-txend: 311126
22:32:13.733 -> 38034539: setupRx2 txrxFlags 0x1 --> 02
22:32:13.733 -> start single rx: now-rxtime: 4
22:32:13.733 -> 38035171: RXMODE_SINGLE, freq=869525000, SF=9, BW=125, CR=4/5, IH=0
22:32:13.834 -> rxtimeout: entry: 38040051 rxtime: 38035164 entry-rxtime: 4887 now-entry: 4 rxtime-txend: 373376
22:32:13.834 -> 38040069: processRx2DnData txrxFlags 0x2 --> 00
22:32:13.834 -> 38040160: processDnData_norx txrxFlags 00 --> 20
22:32:13.834 -> 38040433: engineUpdate, opmode=0x900
22:32:13.904 -> GEIGER: 16 9379 1.705939 0.138929 2 804 606907 1.324750 0.107886
22:32:23.887 -> GEIGER: 9 11428 0.787539 0.064136 1 813 618335 1.314821 0.107077
23:14:36.516 -> GEIGER: 14 10403 1.345766 0.109597 1 4078 3150821 1.294266 0.105403
23:14:40.455 -> GEIGER: Sending to TTN …
23:14:40.490 -> 197201534: engineUpdate, opmode=0x118
23:14:40.490 -> 197201634: TXMODE, freq=867300000, len=25, SF=11, BW=125, CR=4/5, IH=0
23:14:40.490 -> 197201644: setupRx1 txrxFlags 0x21 --> 01
23:14:40.490 -> FAILURE
23:14:40.490 -> G:\Benutzer\rodrigop\Documents\Arduino\libraries\MCCI_LoRaWAN_LMIC_library\src\lmic\radio.c:1065
And here our LoRa Code:
#include “userdefines.h”
// Compile this only if we have a LoRa capable hardware
// loraWan hardware related code
// code based on free-to-use / do-anything-what-you-want-with-it example code
// by Thomas Telkamp, Matthijs Kooijman and Terry Moore, MCCI.
// IOs for optional LoRa
// SX1276 (pin) => ESP32 (pin)
// SCK = GPIO5
// MISO = GPIO19
// MOSI = GPIO27
// CS = GPIO18
// RESET = GPIO14
// DIO0 (8) = GPIO26 (15)
// DIO1 (9) = GPIO33 (13)
// DIO2 (10) = GPIO32 (12)
// Send a valid LoRaWAN packet using frequency and encryption settings matching
// those of the The Things Network.
// This uses OTAA (Over-the-air activation), where where a DevEUI and
// application key is configured, which are used in an over-the-air
// activation procedure where a DevAddr and session keys are
// assigned/generated for use with all further communication.
// Note: LoRaWAN per sub-band duty-cycle limitation is enforced (1% in
// g1, 0.1% in g2), but not the TTN fair usage policy.
// To use this code, first register your application and device with
// the things network, to set or generate an AppEUI, DevEUI and AppKey.
// Multiple devices can use the same AppEUI, but each device has its own
// DevEUI and AppKey.
// Do not forget to define the radio type correctly in
// arduino-lmic/project_config/lmic_project_config.h or from your BOARDS.txt.
#include <Arduino.h>
#include <lmic.h>
#include <hal/hal.h>
#include “hal/heltecv2.h”
#include <SPI.h>
#include “webconf.h”
#include “utils.h”
#include “loraWan.h”
#include “log.h”
// All these 3 LoRa parameters (DEVEUI, APPEUI and APPKEY) may be copied literally from the TTN console window.
// The necessary reversal on DEVEUI and APPEUI is done by hex2data.
void os_getArtEui(u1_t *buf) {
(void) hex2data(buf, (const char *) appeui, 8);
reverseByteArray(buf, 8);
void os_getDevEui(u1_t *buf) {
(void) hex2data(buf, (const char *) deveui, 8);
void os_getDevKey(u1_t *buf) {
(void) hex2data(buf, (const char *) appkey, 16);
// Schedule TX every this many seconds (might become longer due to duty cycle limitations).
const unsigned TX_INTERVAL = 10;
// Pin mapping
const lmic_pinmap lmic_pins = {
.nss = LORA_CS,
.rxtx = LMIC_UNUSED_PIN,
.rst = LORA_RST,
.dio = {LORA_IRQ, LORA_IO1, LORA_IO2 },
static volatile transmissionStatus_t txStatus;
static uint8_t *__rxPort;
static uint8_t *__rxBuffer;
static uint8_t *__rxSz;
void event_log(const char *event) {
log(DEBUG, “%09d: %s”, os_getTime(), event);
void onEvent(ev_t ev) {
switch (ev) {
case EV_SCAN_TIMEOUT:
txStatus = TX_STATUS_ENDING_ERROR;
event_log(“EV_SCAN_TIMEOUT”);
case EV_BEACON_FOUND:
txStatus = TX_STATUS_UNKNOWN;
event_log(“EV_BEACON_FOUND”);
case EV_BEACON_MISSED:
event_log(“EV_BEACON_MISSED”);
case EV_BEACON_TRACKED:
event_log(“EV_BEACON_TRACKED”);
case EV_JOINING:
txStatus = TX_STATUS_JOINING;
event_log(“EV_JOINING”);
case EV_JOINED:
txStatus = TX_STATUS_JOINED;
event_log(“EV_JOINED”);
u4_t netid = 0;
devaddr_t devaddr = 0;
u1_t nwkKey[16];
u1_t artKey[16];
LMIC_getSessionKeys(&netid, &devaddr, nwkKey, artKey);
String ak, nk;
for (int i = 0; i < sizeof(artKey); ++i) {
ak += String(artKey[i], 16);
for (int i = 0; i < sizeof(nwkKey); ++i) {
nk += String(nwkKey[i], 16);
log(DEBUG, “netid: %d devaddr: %x artKey: %s nwkKey: %s”, netid, devaddr, ak.c_str(), nk.c_str());
// Disable link check validation (automatically enabled
// during join, but because slow data rates change max TX
// size, we don’t use it in this example.
LMIC_setLinkCheckMode(0);
// This event is defined but not used in the code.
// No point in wasting codespace on it.
// case EV_RFU1:
// event_log(“EV_RFU1”);
// break;
case EV_JOIN_FAILED:
event_log(“EV_JOIN_FAILED”);
case EV_REJOIN_FAILED:
event_log(“EV_REJOIN_FAILED”);
case EV_TXCOMPLETE:
event_log(“EV_TXCOMPLETE (includes waiting for RX windows)”);
txStatus = TX_STATUS_UPLINK_SUCCESS;
if (LMIC.txrxFlags & TXRX_ACK) {
txStatus = TX_STATUS_UPLINK_ACKED;
event_log(“Received ack”);
if (LMIC.dataLen) {
log(DEBUG, “Received %d bytes of payload”, LMIC.dataLen);
if (__rxPort != NULL) *__rxPort = LMIC.frame[LMIC.dataBeg - 1];
if (__rxSz != NULL) *__rxSz = LMIC.dataLen;
if (__rxBuffer != NULL) memcpy(__rxBuffer, &LMIC.frame[LMIC.dataBeg], LMIC.dataLen);
txStatus = TX_STATUS_UPLINK_ACKED_WITHDOWNLINK;
case EV_LOST_TSYNC:
event_log(“EV_LOST_TSYNC”);
case EV_RESET:
event_log(“EV_RESET”);
case EV_RXCOMPLETE:
// data received in ping slot
event_log(“EV_RXCOMPLETE”);
case EV_LINK_DEAD:
event_log(“EV_LINK_DEAD”);
case EV_LINK_ALIVE:
event_log(“EV_LINK_ALIVE”);
// case EV_SCAN_FOUND:
// event_log(“EV_SCAN_FOUND”);
// break;
case EV_TXSTART:
event_log(“EV_TXSTART”);
log(DEBUG, “Unknown event: %u”, (unsigned int) ev);
void setup_lorawan() {
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 1 / 100);
// Setup the LoRaWan stack for TTN Europe
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI); // g2-band
LMIC.dn2Dr = SF9;
LMIC_setDrTxpow(DR_SF7, 14);
// Send LoRaWan frame with ack or not
// - txPort : port to transmit
// - txBuffer : message to transmit
// - txSz : size of the message to transmit
// - ack : true for message ack & downlink / false for pure uplink
// When Ack is false, the downlink buffer can be set to NULL as rxSz and rPort
// - rxPort : where to write the port where downlink has been received
// - rxBuffer : where the downlinked data will be stored
// - rxSz : size of received data
transmissionStatus_t lorawan_send(uint8_t txPort, uint8_t *txBuffer, uint8_t txSz, bool ack, uint8_t *rxPort, uint8_t *rxBuffer, uint8_t *rxSz) {
// Check if there is not a current TX/RX job running
if (LMIC.opmode & OP_TXRXPEND) {
log(DEBUG, “OP_TXRXPEND, not sending”);
return TX_STATUS_ENDING_ERROR;
} else {
__rxPort = rxPort;
__rxBuffer = rxBuffer;
__rxSz = rxSz;
// Prepare upstream data transmission at the next possible time.
LMIC_setTxData2(txPort, txBuffer, txSz, ((ack) ? 1 : 0));
// wait for completion
uint64_t start = millis();
while (true) {
switch (txStatus) {
case TX_STATUS_UNKNOWN:
case TX_STATUS_JOINING:
case TX_STATUS_JOINED:
os_runloop_once();
case TX_STATUS_UPLINK_SUCCESS:
case TX_STATUS_UPLINK_ACKED:
case TX_STATUS_UPLINK_ACKED_WITHDOWNLINK:
case TX_STATUS_UPLINK_ACKED_WITHDOWNLINK_PENDING:
return txStatus;
case TX_STATUS_ENDING_ERROR:
case TX_STATUS_TIMEOUT:
if (millis() - start > LORA_TIMEOUT_MS) {
setup_lorawan();
return TX_STATUS_TIMEOUT;
hi,
We did not do Lmic support.
Maybe you can try our LoRaWAN code:
