I have been having probolems with the wireless shell booting up and with some code running especially when the Wireless and LoRa fire up. I just checked the voltages and it would appear that it is getting draged down on startup and even when it starts runing I am seeing a running voltage of 2.905 Volts THe one I have on test at the moment finally started however its sitting down at 2.996V.
I gave some 3.3V PSU’s that I may hook up and see if that sorts the problem out.
Its strange as the current load is only 35.7ma.
