I am trying to create a lorawan Bridge for BLE, is it possible to not send the bridge to sleep during the sleep cycle so i can continue to pick up BLE and just run the duty cycle manually as the process is not battery dependent?
I have found in the sleep cycle code for Cubecell that all i have to do is remove the sleep timer cycle
Example:
But for the esp32 it seems there is some code being run directly in the MCU.Sleep function that lora depends on to function properly so when i try to bypass that to stop the esp32 from sleeping lora does not work.
example:
I would look more in depth myself into the MCU class but it is written in assembly. if possible can you direct me to a LORA script that doesnt need this MCU.Sleep function to run
