WiFi Lora V3 node cannot connect to TTN via HT-M01S
I have bought a gateway HT-M01S and it can successfully connected to TTN. Now I want to connect my WiFi Lora V3 node to it and connect to TTN.
I’ve set the following parameters per below after entering the TTN console and register the V3 node as an end device:
/* OTAA para*/
uint8_t devEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x05, 0xA0, 0xE7 };
uint8_t appKey[] = { 0xC1, 0xAE, 0x15, 0x9D, 0x98, 0x59, 0x0E, 0xD3, 0x68, 0x39, 0x51, 0x5A, 0xF1, 0x2F, 0x93, 0x81 };
The following is the input of TTN end device information. JoinEUI = appEui; devEui & appKey are generated by TTN and then input into the above Arduino codes. Attached is the setting in the console.
However, we cannot connect to the TTN network server. Anyone can help?
Are the parameters in General information not correct? Are the ABP parameters in Arduino codes not important? Please advise.
Thanks!!
Check the gateway log.
  1. How to get the gateway log?
  2. I’ve got the attached messages in the TTN console. Any hint?
I also get gateway data from the TTN console per attached. Please help.
To make things simple, can the Heltec officials provide the verified program that I can simply download to my Lora WiFi node V3 and then transmit data to my HelTec gateway?
I think it should work as my node and gateway are from HelTec and I buy this gateway based on Heltec officials’ recommendations.
Hope I can hear a reply from HelTec officials shortely.
Thanks!!
Install this library. The examples in it can be used directly.
https://docs.heltec.org/en/node/esp32/quick_start.html
Yes, I’ve installed this library and use the HelTec example “LoraWan” to modify to the codes below.
Please kindly review what is the problem? Or there is another better program to use?
Thanks!!
include "LoRaWan_APP.h"
/* OTAA para*/
/* ABP para*/
uint8_t nwkSKey[] = { 0xC1, 0xAE, 0x15, 0x9D, 0x98, 0x59, 0x0E, 0xD3, 0x68, 0x39, 0x51, 0x5A, 0xF1, 0x2F, 0x93, 0x81 };
uint8_t appSKey[] = { 0xC1, 0xAE, 0x15, 0x9D, 0x98, 0x59, 0x0E, 0xD3, 0x68, 0x39, 0x51, 0x5A, 0xF1, 0x2F, 0x93, 0x81 };
uint32_t devAddr =  ( uint32_t )0x007e6ae1;
DeviceClass_t  loraWanClass = CLASS_A;
/*the application data transmission duty cycle.  value in [ms].*/
/*OTAA or ABP*/
/*ADR enable*/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first)       | DR
* 2               | DR
* 3               | max(DR-1,0)
* 4               | max(DR-1,0)
* 5               | max(DR-2,0)
* 6               | max(DR-2,0)
* 7               | max(DR-3,0)
* 8               | max(DR-3,0)
    appDataSize = 4;
    appData[0] = 0x00;
    appData[1] = 0x01;
    appData[2] = 0x02;
    appData[3] = 0x03;
//if true, next uplink will add MOTE_MAC_DEVICE_TIME_REQ
  Mcu.begin();
  switch( deviceState )
    case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
    case DEVICE_STATE_JOIN:
      LoRaWAN.join();
    case DEVICE_STATE_SEND:
      prepareTxFrame( appPort );
      LoRaWAN.send();
    case DEVICE_STATE_CYCLE:
    case DEVICE_STATE_SLEEP:
      LoRaWAN.sleep(loraWanClass);
Any news and hints from HelTec officials? Is it really possible to link to TTN? If not, please change your website to the public that it is NOT LoraWan compliant. Thank you!!
Connect CubeCell to LoRaWAN Server — cubecell latest documentation (heltec.org)
I’ve tried and finally successful by selecting the device as WiFi Lora node (v2).
Thank you very much!!
If you are in the USA and are having trouble getting your Heltec LoRa device to connect to TTN, you may want to take a look at my blog post. I lost many hours of my life getting my CubeCell to talk to TTN and my write-up may same you some frustration.
