I’m trying to use the WiFi LoRa V2 board to connect through my 915MHz gateway here in the US, and not having any luck.
I’m using the OLED_LoRa_Sender script, set the band to 915E6, and loaded it. I’m getting nothing through a working gateway.
Has anyone else run these boards, using the Heltec libraries, at 915MHz?
