WiFi LoRa 32(V4.3), ESP32S3 + SX1262 LoRa Node
Firmware: MeshCore v1.17.1-d929643 (BLE Companion)
Problem: After disconnecting and later reconnecting via Bluetooth, I can no longer receive any messages. The noise floor reads -114 dBm and nothing else in my setup has changed. Interestingly, transmit and receive both work fine on the initial Bluetooth connection — the issue only appears after a disconnect and reconnect.
What I’ve tried (none of which fixed it):
  • Setting agc.reset.interval 4 followed by a reboot
  • Removing the BLE connection and pairing/reconnecting again
Workaround: Reinstalling the firmware restores normal operation every time.
