Tried compiling this library in arduino IDE Heltec ESP32 library but LoraWan_App.h is missing.
Even if I include the Lorwan library from * [Resource] — Heltec ESP (ESP32&ESP8266) framework (Include LoRaWAN library) still getting some errors…
Error message in Arduino ide
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionAS923.c: In function ‘RegionAS923TxConfig’:
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionAS923.c:694:71: error: ‘LORAWAN_PREAMBLE_LENGTH’ undeclared (first use in this function)
Radio.SetTxConfig( modem, phyTxPower, 0, bandwidth, phyDr, 1, LORAWAN_PREAMBLE_LENGTH, false, true, 0, 0, false, 3e3 );
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionAS923.c:694:71: note: each undeclared identifier is reported only once for each function it appears in
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionAU915.c: In function ‘RegionAU915TxConfig’:
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionAU915.c:592:72: error: ‘LORAWAN_PREAMBLE_LENGTH’ undeclared (first use in this function)
Radio.SetTxConfig( MODEM_LORA, phyTxPower, 0, bandwidth, phyDr, 1, LORAWAN_PREAMBLE_LENGTH, false, true, 0, 0, false, 3e3 );
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionAU915.c:592:72: note: each undeclared identifier is reported only once for each function it appears in
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionCN470.c: In function ‘RegionCN470TxConfig’:
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionCN470.c:558:64: error: ‘LORAWAN_PREAMBLE_LENGTH’ undeclared (first use in this function)
Radio.SetTxConfig( MODEM_LORA, phyTxPower, 0, 0, phyDr, 1, LORAWAN_PREAMBLE_LENGTH, false, true, 0, 0, false, 4000 );
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionCN470.c:558:64: note: each undeclared identifier is reported only once for each function it appears in
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionCN779.c: In function ‘RegionCN779TxConfig’:
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionCN779.c:632:71: error: ‘LORAWAN_PREAMBLE_LENGTH’ undeclared (first use in this function)
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionCN779.c:632:71: note: each undeclared identifier is reported only once for each function it appears in
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionEU433.c: In function ‘RegionEU433TxConfig’:
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionEU433.c:631:71: error: ‘LORAWAN_PREAMBLE_LENGTH’ undeclared (first use in this function)
c:\Users\C11421\Documents\Arduino\libraries\Heltec_ESP32_Dev-Boards\src\loramac\region\RegionEU433.c:631:71: note: each undeclared identifier is reported only once for each function it appears in
exit status 1
1)) What is the procedure to test the Lora data transfer and receive?
2)) How to test the example code. what procedures to follow. As a beginner please guide us to test these using arduino ide
