wifi lora 32 v3的驱动在哪里下载
You can install into the Arduino environment by searching for
https://docs.heltec.org/en/node/esp32/quick_start.html#via-arduino-board-manager
Install the board through the boardmanager and it will install Heltec ESP32 Series Dev-boards version 0.0.7
This will add most of the libraries bit you should install Adafruit SSD1306 V2.5.7 and MCCI LoRaWAN LMIC library by IBM version 4.1.1
