Someone could help me I’m a little confused, I’m needing the SDA and SCL outputs to connect a temperature sensor MX30100 on the WIFI LORA 32 V3 board and to be able to read the data emitted by the sensor, I have observed that the WIFI LORA 32 V3 board uses the ESP32-S3 chip which does have these pins, but in the diagram of output pins I only find the pins OLED_SDA= pin17 and OLED_SCL= pin 18. I don’t really know if these pins serve as output but I found them at the bottom of the board.
Necesito saber si es posible tener estos pines de salida para poder conectar el sensor que utiliza los pines SDA y SCL. En caso de ser posible como seria el metodo
