I finally made WiFi_LoRa_32_v3 board well compiled in the Platformio but it keeps rebooting with below info, any idea about this issue ?
thanks
Jun
The compile process info as below:
Processing heltec_wifi_lora_32_V3 (platform: https://github.com/Baptou88/platform-espressif32.git; board: heltec_wifi_lora_32_V3; framework: arduino)
Verbose mode can be enabled via -v, --verbose option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/heltec_wifi_lora_32_V3.html
PLATFORM: Espressif 32 (5.2.0+sha.97b8cd2) > Heltec WiFi LoRa 32 (V3)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
DEBUG: Current (esp-builtin) On-board (esp-builtin) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
- tool-esptoolpy @ 1.40201.0 (4.2.1)
- toolchain-riscv32-esp @ 8.4.0+2021r2-patch3
- toolchain-xtensa-esp32s3 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ deep+, Compatibility ~ soft
Found 35 compatible libraries
Scanning dependencies…
Dependency Graph
|-- Heltec ESP32 Dev-Boards @ 1.1.1
| |-- Wire @ 2.0.0
| |-- SPI @ 2.0.0
|-- ESP32_LoRaWAN @ 2.1.1
| |-- SPI @ 2.0.0
| |-- Wire @ 2.0.0
|-- RadioLib @ 5.6.0
| |-- SPI @ 2.0.0
|-- SPI @ 2.0.0
|-- Wire @ 2.0.0
Building in release mode
Retrieving maximum program size .pio/build/heltec_wifi_lora_32_V3/firmware.elf
Checking size .pio/build/heltec_wifi_lora_32_V3/firmware.elf
Advanced Memory Usage is available via “PlatformIO Home > Project Inspect”
RAM: [ ] 5.0% (used 16276 bytes from 327680 bytes)
Flash: [= ] 9.8% (used 327221 bytes from 3342336 bytes)
========================================================================= [SUCCESS] Took 2.77 seconds =========================================================================
- Terminal will be reused by tasks, press any key to close it.
The reboot info as below
Rebooting…
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x4202ceca
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x39c
load:0x403c9700,len:0x9bc
load:0x403cc700,len:0x28dc
entry 0x403c98c0
[ 122][E][Wire.cpp:422] beginTransmission(): could not acquire lock
[ 123][E][Wire.cpp:526] write(): NULL TX buffer pointer
[ 128][E][Wire.cpp:448] endTransmission(): NULL TX buffer pointer
[ 134][E][Wire.cpp:422] beginTransmission(): could not acquire lock
[ 140][E][Wire.cpp:526] write(): NULL TX buffer pointer
[ 145][E][Wire.cpp:526] write(): NULL TX buffer pointer
[ 150][E][Wire.cpp:448] endTransmission(): NULL TX buffer pointer
[ 156][E][Wire.cpp:422] beginTransmission(): could not acquire lock
[ 162][E][Wire.cpp:526] write(): NULL TX buffer pointer
[ 168][E][Wire.cpp:526] write(): NULL TX buffer pointer
[ 173][E][Wire.cpp:448] endTransmission(): NULL TX buffer pointer
ESP32 MCU init…
ESP32 MCU inited OK!
DevEui=2CF7F1204200xxxx
LoRaWAN US915 Class A start!
joining…
TX on freq 904600000 Hz at DR 4
Guru Meditation Error: Core 1 panic’ed (InstrFetchProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x00000000 PS : 0x00060430 A0 : 0x82006cd8 A1 : 0x3fce2eb0
A2 : 0x3fc94de8 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x3fc9249b
A6 : 0x3fc92494 A7 : 0x00000000 A8 : 0x820020e3 A9 : 0x3fce2e80
A10 : 0x00000000 A11 : 0xffffffff A12 : 0x00000000 A13 : 0x3fc94ea8
A14 : 0x0000005f A15 : 0x3fce2e50 SAR : 0x0000000e EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000 LBEG : 0x40054bf0 LEND : 0x40054c0f LCOUNT : 0x00000000
Backtrace:0xfffffffd:0x3fce2eb00x42006cd5:0x3fce2ed0 0x4200cd5d:0x3fce2ef0
#0 0xfffffffd:0x3fce2eb0 in ?? ??:0
#1 0x42006cd5:0x3fce2ed0 in loop() at src/main.cpp:173
#2 0x4200cd5d:0x3fce2ef0 in loopTask(void*) at /Users/junwen/.platformio/packages/framework-arduinoespressif32@3.20005.220925/cores/esp32/main.cpp:50
ELF file SHA256: 0000000000000000
