Trying to figure out pins required. Cannot find 22scl or sda pin out.
So much info out there that comes close but not the same.
Try this post:
I am also looking for a working sketch for the collaboration between Heltec LoRa32 V3.1 and a BME280.
I have read a lot on the internet recently and tried out many examples, but I cannot get this combination to work.
However, with a Heltec Lora32 V2 I have no problems operating a BME 280. It works perfectly.
A bit more information as to what isn’t working might help.
The most obvious difference between the V3 boards and earlier versions is the need to [declare and] use the second I2C bus for the sensor.
The only way that should work is via the rear pins 17 and 18. These are not brought out, so you have to solder. But I don’t dare to do that.
So I thought there must be alternative pins.
Unfortunately, I don’t know much about the second I2C bus yet.
When using the V3 board, you have to define and use the second I2C bus, NOT the first one.
Can you give me an example for the bme280 (with the working pins)?
The best I can do for you at the moment is point you to my project website where the subject is discussed. The panel immediately above this section includes the pin definitions that I use (e.g. in the present case, pins 19 and 20 for SDA and SCL respectively) and I generally use the Adafruit_BME280 library.
Thank you very much for your help. I will look into it soon.
Your website helped me a lot.
With this code (from user machepro) it now works for me:
TwoWire Wire2(1);
In the setup:
Wire2.begin(41,42); /* (GPIO SDA and SCL) */
status = bme.begin(0x76, &Wire2);
Thank you for your help.
