Is it possible to organize a connection between Cubacell 1/2AA Node (transmitter) and WiFi LoRa 32 (V2) (receiver) based on the examples? If so, which variables should be set. Thanks!
WiFi LoRa 32 (V2) + CubeCell 1/2AA Node
Yep you can use the basic Sender and Receiver code sample that allows to do that easily and you basically just need to setup in it the Frequency for your area and that’s it ! I tested it other day and it works perfect !
