Want to connect a Bosch BME680 sensor via I2C to the LoRa 32 V2. Does work on hardware side. I can succesfully scan the sensor on 0x77.
But, if I want to use the original Bosch libraries to read out the values for temterature and others, the library uses the common <math.h> functions sqrtf and powf for data type float.
The library libm.a at …/hardware/heltec/esp32/tools/sdk/lib seens not to be complete in respect to float values.
Is there anything I can do to get raw values compensated already on LoRa 32 and not later on a processing computer?
libm.a(lib_a-ef_pow.o):(.literal+0x80): undefined reference to __ieee754_sqrtf' libm.a(lib_a-ef_pow.o): In function__ieee754_powf’
