I have several routers running an openwrt variant. Some are based on the MT-7622, the MT-7621 and broadcom based routers. My WiFI Kit32 connects flawlessly in under 5 seconds to both the MT-7621 and the broadcom based routers, but has issues connecting with the MT-7622.
Hostapd will report
BlueZebra-linux: ~ # logread -f | grep -i 14:3A:F8
Wed Mar 9 21:27:14 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
Wed Mar 9 21:27:24 2022 daemon.info hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: disassociated
Wed Mar 9 21:27:25 2022 daemon.info hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Wed Mar 9 21:28:06 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
Wed Mar 9 21:28:48 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
Wed Mar 9 21:29:31 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
Wed Mar 9 21:30:13 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
Wed Mar 9 21:30:55 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
Wed Mar 9 21:31:37 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
Wed Mar 9 21:32:14 2022 daemon.notice hostapd: wifi2g: STA 30:c6:f7:14:3a:f8 IEEE 802.11: did not acknowledge authentication response
It might connect eventually (minutes later) or it might not at all.
I’ve also tried the same tests with a WiFi Lora kit as well as several esp33’s and esp8266 boards, they all connect fine to the MT-7622.
Has anyone else seen this behavior?
