Hi all
I’m using a WiFi Kit 32 v2 with the Arduino IDE.
Whatever I do the serial output comes through corrupted:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1256
load:0x40078000,len:13832
load:0x40080400,len:4
load:0x40080404,len:3048
entry 0x40080590
��r�� ��{��d��r�� ��r�� ��r�� ��{��`��r�� ��{��`��{��d���|�� ��r�� ���|�� ��r�� ��{��`��r�� ���|�� ��r�� ���|��`��{��`��{��`���|��`���|��`��r��
As you can see the bootloader shows up correctly and everything after is unreadable.
This is the code I’m testing with:
  Serial.println("test");
The serial monitor is set to 115200 baud rate, I’ve also tried many other combinations.
Any advice appreciated.
