I cant format/mount the flash memory using SPIFFS. I always get the error -10025.
Is the flash accessible in WIFI KIT 32, or not ? because in the board menu the flash is not mentioned at all like in other ESP32 boards.
Any hints ?
KLaus
WIFI KIT 32 : SPIFFS mount issue -10025
Hi Klaus,
I assume you’re using a “Wifi kit 32 v3”, if I’m not mistaken that’s an ESP32-S3. The standard SPIFF tool set doesn’t support S3. I’m running into a similar problem.
Frank
