When the board arrived, it was working well, wifi and screen.
I uploaded the classic blink and everithing was ok.
Now it was time to make the OLED work,
i’ve worked with them before but it was with an arduino pro micro,
after uploading the example, nothing worked, tested around and this is what i know:
- the board boots
- nothing appears on screen
- the board resets when any
Heltec.displaymethod is called
need some help solving this
edit:
When calling any Heltec.display method this appears on the serial monitor
ELF file SHA256: fd4d2b96ec26363e
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x420218fa
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbe4
load:0x403cc700,len:0x2a38
entry 0x403c98d4
Serial initial done
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x420016bf PS : 0x00060630 A0 : 0x82001675 A1 : 0x3fcebe20
A2 : 0x00000000 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x00000001
A6 : 0x00000001 A7 : 0x1c03a180 A8 : 0x820016b9 A9 : 0x3fcebdd0
A10 : 0x00000003 A11 : 0x00000003 A12 : 0x00000000 A13 : 0x0000002c
A14 : 0x0000002b A15 : 0x0000e100 SAR : 0x00000010 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000018 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xfffffffa
Backtrace: 0x420016bc:0x3fcebe20 0x42001672:0x3fcebe40 0x42002a9a:0x3fcebe60
