WiFi-Kit-32 Programming no longer works
Hi
I have used sever of These kits and all went well so far.
But now, after several Updates of Windows and Arduino (Windows 10 newset, Arduino 1.8.9, ESP32 1.02), I can still download, but the module crashes with the following info:
********* Quote ***********
Backtrace: 0x4008a99c:0x3ffd3db0 0x4008aa9b:0x3ffd3dd0 0x401339ff:0x3ffd3df0 0x40138368:0x3ffd3e20 0x40138a22:0x3ffd3e40 0x40138d51:0x3ffd3e90 0x40137e14:0x3ffd3ef0 0x401379d6:0x3ffd3f40 0x40137a6f:0x3ffd3f60 0x40137aba:0x3ffd3f80 0x400d4778:0x3ffd3fa0 0x4014ae16:0x3ffd3fc0 0x40135d83:0x3ffd3ff0
Rebooting…
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:956
load:0x40078000,len:0
load:0x40078000,len:13076
entry 0x40078a58
assertion “false && “item should have been present in cache”” failed: file “/Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/nvs_flash/src/nvs_item_hash_list.cpp”, line 85, function: void nvs::HashList::erase(size_t)
abort() was called at PC 0x401339ff on core 0
********* unquote *************
What’s wrong now?
Any help welcome. Thanks and
best regards
Thomas
Have you tried doign a full erase on the chip?
I am no expert but since no one has answered this give that a go and see if it sorts it out.
You may also want to try this out.
Ok after I discovered that all still works on another PC I reinstalled the Heltec Software and now all is OK again. Hmmm. Somtimes….
Sorry for disturbing you.
Regards
Thomas
