WiFi HaLow series for Europe
Hi folks,
I’ve seen the new WiFi HaLow series, but it operates at 902 - 928 MHz. This frequency is not allowed in Europe. Are there any plans to launch these products in other regions?
And just for the sake of understanding:
WiFi HaLow in this case means that I can connect a lot of devices to the HaLow router, so everything basically works like normal WiFi, but slower (and with less data transfer) because of the lower frequency, right?
From the router description, I understood that I could use the router to connect my end devices to the AWS IoT MQTT client in a simple way. Is this correct?
Cheers
Hello, friend. Our WiFi HaLow series is currently only available in the 902 to 928 frequency band. We will notify you as soon as we introduce other frequency bands. Thank you for your support and understanding.
hello there,
I saw that your gateway are support 868mhz, but the stick not. you able to specify a date, that stick will be avaliable with 868 mhz version?
Hello Vamp, damm it cost me an entire day to find out why this system did not work for me. Did u find a solution ? Are u using it with a different stick ? Would be nice to connect have little issue with my and not sure which antenna to purchase
