What will be used? Settings in program or arduino IDE (LoRaWAN)
Hello, the same settings can i do in the arduino ide!
/OTAA or ABP/
/ADR enable/
Wich command will be used when differend settings are done?
Greetings
E_T
May be this helps
https://docs.platformio.org/en/latest/platforms/asrmicro650x.html#configuration
Thank you, i use the arduino ide!
E_T
I believe I have overridden “some” of the vars within the program successfully when using the Arduino IDE,
But had less success with Platformio.
Not too helpful I know.
I believe to have found out the following facts:
The variables contain the value of the default settings of the Arduino IDE and do not stand for a defined value!
E_T
