Hi!
I’m trying to connect mit LoRa-ESP32 with an ePaper-Display from Waveshare.
Therefore I’m using the GxEPD2 Library, but this does not work (with the library givven by waveshare the display works, but the usage is disgusting…).
Know, I don’t know if the Libraries and includes are not correct or the pin-setup. Maybe some of you already connected such a display to that ESP.
My Pin-Setup is:
GND -> GND
3.3 -> VCC
DIN -> 27 LORA_MOSI
CLK -> 5 LORA_SCK, VSPI_CSO
DC -> 15 OLED_SCL (I’m not using the onboard OLED)
CS -> 4 OLED_SDA
RST -> 16 OLED_RST
BUSY -> 36
Is this Pin-Setup useable? Do you have ideas or working includes for the Heltec ESP and GxEPD2?
SUT_2
