We have a new handy tool on the CubeCell basis.
WASN LoRaWAN Mapper
It combines a little hardware dongle (CubeCell Module and GPS) with a nice Software.
It only uses 1 USB port for both devices. A short antenna for LoRaWAN is attached and a GPS antenna is integrated, but you can add the antennas you want for LoRaWAN and GPS using the SMA connectors,
Now you can quickly test LoRaWAN coverage with OTAA or ABP authentication with confirmed transmits.
The software logs the position and position quality and the LoRaWAN signal quality.
We designed it for field testing the LoRaWAN coverage to find good mounting points for new gateways.
All LoRaWAN testers we have found are terrible expensive (150 EUR and up), this little dongle will only be about 50 EUR and the software is absolutely free.
Hope to release a beta to the public in a week.
