Warning after installing 0.0.5
After installing 0.0.5, and fixing all the naming convention errors, I am still left with a warning.
WARNING: library LoRa claims to run on ASR650x-Arduino architecture(s) and may be incompatible with your current board which runs on CubeCell architecture(s).
Should I be worried about this?
That is only a warning and no error.
Not all library.properties have been changed. This is only a string in the file.
The CubeCells are using a ASR6501 mcu
OK, I’ll ignore it…
Hi yes works ok with this warning
Simon
