Vextoff / vexton issue -
Can someone help me out with part of the code ?
When i comment out //Vextoff; it works , but my goal is that aftere measurement vext is turn off.
What i am doing wrong ?
// Turn ext 3.3V
void VextOn()
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
delay(250);
void VextOff()
digitalWrite(Vext, HIGH);
VextOn();
int senseDist;
#ifdef USE_VL53L1X
    // Try a couple of readings to clear indeterminate values
    int tryCount = 5;
    do
        senseDist = sensor.readRangeSingleMillimeters();
        tryCount--;
        #ifdef DEBUG
            Serial.print("got reading ");
            Serial.println(senseDist);
    while( (senseDist == 8190) && (tryCount != 0) );
    if (senseDist == 8190) {
        // If we still get an indeterminate reading, return 0
        senseDist = 0;
    if (sensor.timeoutOccurred()) {
        senseDist = 1;
// VextOff(); <-- here with // it ok
if (firstMeasurement)
if (senseDist == 0)
// Set RGB LED to red for the first measurement
pixelss.setPixelColor(0, pixelss.Color(255, 0, 0));
else
// Set RGB LED to green for the first measurement
pixelss.setPixelColor(0, pixelss.Color(0, 255, 0));
    pixelss.show(); // Send the updated pixel colors to the hardware.
    delay(500);
    // Turn off the RGB LED
    pixelss.setPixelColor(0, pixelss.Color(0, 0, 0));
    pixelss.show();
    firstMeasurement = false; // Mark that the first measurement has been done
uint16_t voltage = getBatteryVoltage();
appDataSize = 4;
appData[0] = senseDist >> 8;
appData[1] = senseDist;
appData[2] = voltage >> 8;
appData[3] = voltage;
Hi ,
Think manage to off vext , no power on it now when checking by multimeter .
However i do have still 3,5V on VDD - question , how to disable VDD pin ?
vdd3.3V好像是无法关闭的,因为vdd3.3V与gnss备份域相关,只要有电池或者usb,都会使vdd3p3引脚输出3.3v电压
