I am working with Heltec Wifi LoRa 32 (v2) for a small project. My aim is to acquired analog data from the ADCs and transmit this data via LoRa.
I am trying to configure pins 34,35,27 and 14 as ADCs (along with a few more). Once I power up the board, the LoRa says “Starting LoRa failed!”. However, I am able to use LoRa if I am not configuring these pins as ADCs.
My question is, Is not possible to use LoRa defined pins for any other purpose if I am using LoRa on board? If it is possible, could someone please let me know the method to enable ADCs and LoRa to be used simultanesly?
Thanks in advance
