USB or SPI with existing USB header? LORA V2 Dev
I’m looking to utilize, if possible, the existing physical USB header on the V2 dev board to read an SD-card, either via USB D+/D- or SPI. This is not immediately clear based on the pinout diagrams. I’ve tried searching around without much luck because its mainly used for either power, flashing or serial debugging.
Thanks!
I hope it will be helpful to you
