i have some problems to update the Arduino-DevelopmentFramework for CubeCell with git!
The framework 1.2.0 is installed with Arduino-Boardmanager!
The path in the description is not available for me.
4. Open /Documents/Arduino/hardware/CubeCell/ASR650x-Arduino/tools and double-click get.exe
My path is: C:\Users\xxxxx\AppData\Local\Arduino15\packages\CubeCell\hardware\CubeCell\1.2.0\cores\asr650x\cores
Wich path should i take for the command: 3. Execute the command under the \Documents\Arduino\hardware\CubeCell path (Must in this path),
After that, there is no file get.exe
E_T
