I’m not able to join the Helium network using the example project that comes with the board libraries. I updated the DevEui, AppEui, and AppKey but it still won’t connect. I have other LoRaWAN devices / nodes that work so I know it’s not a reception issue. I used MSB (Big Endian) values for the DevEui and AppEui, and LSB (Little Endian) for the AppKey.
Is anyone able to see what I’m doing wrong? Thanks!
#include “LoRaWan_APP.h”
#include “Arduino.h”/*
- set LoraWan_RGB to Active,the RGB active in loraWan
- RGB red means sending;
- RGB purple means joined done;
- RGB blue means RxWindow1;
- RGB yellow means RxWindow2;
*//* OTAA para*/
uint8_t devEui[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t appKey[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };/* ABP para*/
uint32_t devAddr = ( uint32_t )0x007e6ae1;/LoraWan channelsmask, default channels 0-7/
uint16_t userChannelsMask[6]={ 0x00FF,0x0000,0x0000,0x0000,0x0000,0x0000 };/LoraWan region, select in arduino IDE tools/
LoRaMacRegion_t loraWanRegion = ACTIVE_REGION;/LoraWan Class, Class A and Class C are supported/
DeviceClass_t loraWanClass = LORAWAN_CLASS;/the application data transmission duty cycle. value in [ms]./
uint32_t appTxDutyCycle = 15000;/OTAA or ABP/
bool overTheAirActivation = LORAWAN_NETMODE;/ADR enable/
bool loraWanAdr = LORAWAN_ADR;/* set LORAWAN_Net_Reserve ON, the node could save the network info to flash, when node reset not need to join again */
bool keepNet = LORAWAN_NET_RESERVE;/* Indicates if the node is sending confirmed or unconfirmed messages */
bool isTxConfirmed = LORAWAN_UPLINKMODE;/* Application port /
uint8_t appPort = 2;
- to the following table:
- Transmission nb | Data Rate
- 1 (first) | DR
- 2 | DR
- 3 | max(DR-1,0)
- 4 | max(DR-1,0)
- 5 | max(DR-2,0)
- 6 | max(DR-2,0)
- 7 | max(DR-3,0)
- 8 | max(DR-3,0)
uint8_t confirmedNbTrials = 4;/* Prepares the payload of the frame */
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
}void setup() {
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
}void loop()
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
